Old 02-21-2012, 01:51 PM   #1
Awning Parts
I have a FS2410, I broke a clip on the awning that I need to replace and cant seem to find it or use the right key words to search for it. When the awning is up you have to press both sides of it to release the awning from the side of your trailer. It snaps on the inside awning bar and then pinch fits to the inside of the second bar to hold it in place when its up. Hope this makes sense, anyone know what this is called or where to get one? I called Stealth and they dont sell that part as it comes with the awning.
dcompton is offline   Reply With Quote
Old 02-21-2012, 02:23 PM   #2
jim44646's Avatar
without seeing it it's hard to tell. does it look like either of these?
jim44646 is offline   Reply With Quote
Old 02-21-2012, 02:35 PM   #3
TURBS's Avatar
I know exactly what ur looking for. Black plastic tabs on each side?
Last time I needed a part that wasn't available seperate for my awning I went to my dealer and found there (damaged) awning pile and found the pieces I was looking for.
I flipped them a 10 spot and was on my way.
Id start there
Old 02-21-2012, 02:41 PM   #4
I think it's this.
Len & Cheri is offline   Reply With Quote
Old 02-21-2012, 02:41 PM   #5
Try here:
Dometic A&E 8300 roll out awning parts,diagram, instructions
Old 02-21-2012, 04:21 PM   #6
jim44646 - looks like the second pic.
LFugate - looks just like the diagram part D4. Is the A&E 8300 the awning on the stealth fs2410?
you guys are awsome and quick on the reply!
Old 02-21-2012, 04:42 PM   #7
You'll need to unroll your awning and look on the silver tube it rolls up on to find your make and model. Once you get that, you should be able to find the part on that site. I used that photo just for example.
Old 02-21-2012, 07:08 PM   #8
Thanks! I'll have a look when I swing by storage
Old 03-12-2012, 03:00 PM   #9
Thanks to those of you who helped! I out the part I needed and after some calling and digging around this was the best place for the part. Some dealers say you cant order it on its own and others want way too much money for it so I wanted to share the info to save some headach and $ if anyone comes across this post.
Dometic 3105278.026 Sunchaser NSTD Travel Latch Camper Trailer RV
awning
