Old 10-11-2014, 10:05 AM   #1
Send a message via Skype™ to Racersteve
Battery cutoff and solar
Does the red battery cut off switch prevent solar trickle charging when in off position? Thanks!
Racersteve is offline   Reply With Quote
Old 10-11-2014, 05:37 PM   #2
In most applications, no. That''s generally between your batteries and house 12v power. Just check the leads from your solar controller with a multimeter to confirm. It's not a bad idea to add an additional cutoff between your solar controller and batteries as well.
rana is offline   Reply With Quote
Old 10-12-2014, 01:10 AM   #3
Jjs2000z's Avatar
No, the solar wires from the controller are directly hooked up to your batteries.
2014 stealth 2714
Jjs2000z is offline   Reply With Quote
Old 10-26-2014, 12:46 PM   #4
How about when you are hooked to shore power does the battery disconnect have to be on to charge the batteries?
MBart is offline   Reply With Quote
Old 10-26-2014, 05:45 PM   #5
Jjs2000z's Avatar
No the solar will charge no matter what the hook up is as long as it's getting g sun, the sat will get your batteries full and fresh.
2014 stealth 2714
Old 10-26-2014, 05:55 PM   #6
I have a cover over my trailer, so I'm not getting any solar power.
Old 10-27-2014, 12:16 AM   #7
Jjs2000z's Avatar
You can check your battery percentage on the go power controller to see if your voltage is there when the main switch is turned of but you are plugged into shore power
2014 stealth 2714
Old 10-27-2014, 05:50 AM   #8
Yes. The disconnect must be "on" in order to charge using shore power.
battery, solar
