I have a 2017 2715FQ Stealth Toy Hauler. Overall we are pleased but are having a few issues with it now. Last year it developed a leak and we had water running out of an electrical outlet in the bed room. We took it to the dealer and they found 'multiple' voids in the sealant on the front cap. After our last trip, I was inspecting the trailer and noticed the siding is separating from the corner molding on the front right corner. It was covered by butyl but the buty is separating and the gap is visible. The butyl on the opposite corner is also starting to come off and revealing a void on that side as well.
Forest River says to remove the corner molding reapply butyl and it will be fine. However, the void is approximately 1/4 inch back from the molding and the butyl will not fill the void.
My dealer says they have experienced this same problem with another trailer that was the same model as mine and that the cap needs to be reset. They don't want to do the 'fix' that Forest River has suggested as they say the issue is bigger than simply applying new sealant.
Has anyone else had warranty issues or experienced an issue with the siding separating? The linked video will give a better explanation.
https://youtu.be/B0-Q6-BH0dI
