Old 01-31-2015, 02:06 PM   #11
Isn't there some sort of reset button located (hidden) on the fridge flue on the outside? Have to remove the exterior fridge grill and the flue is usually on the right hand side of the opening. Just wondering...............
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 01-31-2015, 04:28 PM   #12
Jjs2000z's Avatar
Originally Posted by fonzie View Post
Have you checked your battery voltage with a multimeter...need to be above 12 volts for proper operation....Is propane supply adequate?
Here is manual in case you don't have...
http://www.manualslib.com/products/D...2-2821469.html
Batteries are fine, I have solar on my trailer.
Thanks for the manual. I purchased the second year warranty from forest river directly. Will they cover this? Also I am now having an issue with propane smell in the trailer when the water heater is on. Anyone else have this issue?
2014 stealth 2714
Jjs2000z is offline   Reply With Quote
Old 02-06-2015, 01:16 PM   #13
Stealth13's Avatar
Dumb question but is the little slide thing that holds the thermo bulb up in the cooling fins on the back wall inside the fridge . The higher you slide it the cooler the fridge gets mine slips down occasionally .
Stealth13 is offline   Reply With Quote
Old 02-06-2015, 02:01 PM   #14
Jjs2000z's Avatar
The thermostat on the fins is in the middle
2014 stealth 2714
Old 02-06-2015, 02:20 PM   #15
Mojojojo's Avatar
Try moving it up the fins, get a bottle of water mixed with dish soap and spray all the gas lines you can access if it starts to blow bubbles its leaking also if you smell gas don't touch any switches open everything up and air it out.
My wife keeps saying I don't listen to her -Or something like that?...."My advice has no basis ,more reliable them my own meandering experience" Baz Luhrmann
2011 Sierra 355QBQ 1986 F350
Mojojojo is offline   Reply With Quote
Old 02-06-2015, 03:38 PM   #16
Jjs2000z's Avatar
I do not smell any gas leaking. The condenser is not getting cold.
2014 stealth 2714
Old 03-04-2015, 11:41 PM   #17
northstar1960's Avatar
Check the heat tube on the fridge . wasp nest,or other blockage , if it's heating it should be cooling , if your not level it won't cool . in my popup after a week or two of use the fridge would stop working . seems it would get too hot , the flow of ammonia would stop . If i shut it down for a few hrs let it cool off it would be good again . same can be with the hot water heater . sounds like your smelling exhaust gas , if it were a propane leak you would smell it all the time the propane is on . if you just smell when HWH is running check the vent pipe
northstar1960 is offline   Reply With Quote
Old 03-05-2015, 01:13 AM   #18
Originally Posted by Flybob View Post
Is your unit level? Is the Flue hot?
Hi the trailer needs to be level!!!! If the trailer is not level liquid refrigerant that is in the refrigerator may get trapped in low spots not allowing it to flow back though gravity back to the tank that is heated to start the cooling process.
If the trailer is level and not working the refrigerator most likely has developed a leak and will need to be serviced
Hope this helps Tim
TimVWulp is offline   Reply With Quote
Old 03-05-2015, 03:50 AM   #19
Witch Doctor's Avatar
We leave our trailer in storage out here so do not know if unit works on electric. Hopefully this will be covered under the warranty. I pushed the second year warranty when we bought this trailer.
The trailer is level
I think Your unit Refer has a 2 year warranty from Dometic. Call them and take it to there service rep. Most dealers do not know how to troubleshoot them. They have dealers all over....You will need the model# and serial#.
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-03-2015, 04:55 PM   #20
My Dometic in my '14 WA2313 had a problem from day one. It wouldn't get cold enough and when out on the road would quit cooling all together. I think it was partially clogged.
It was in the shop four or five times and they always said it was fine. I eventually called Dometic directly and got a high level warranty person involved. Once I thoroughly explained everything to her she had a new one overnighted and my shop put it in. Has worked great ever since.
Dometic has great customer service once you find the right person.
FR Stealth 2313
Chevy 2500HD Duramax
hammick is offline   Reply With Quote
dometic
