Is your freezer working? I had issues due to poor ventilation and air circulation around the condenser. My freezer would work but the fridge struggled. Also, there is a possibility a nest of insects could be blocking the flu if it's been sitting outside for a long time. Make sure you have room for air to circulate inside the cabinet also. Mine had 2 glass type fuses on the control board which runs the electronics. The jet on the gas may also need cleaning. Man that bites to be having that issue when chillin.
2014 Windjammer 3025W Diamond 34.5 ft 8300 lbs.
2010 F150 SC XLT 4x4 5.4L, 3.55 gears 20" rims
12 k Equalizer WDH, Firestone Airbags, HD Bilsteins
TST 507RV TPMS
