Old 01-30-2015, 08:03 PM   #1
Jjs2000z's Avatar
Dometic DM2852RBFX not cooling
My fridge turns on propane however the fridge is not getting cold. Any ideas?
2014 stealth 2714
Jjs2000z is offline   Reply With Quote
Old 01-31-2015, 05:37 AM   #2
fonzie's Avatar
Usually takes about 8 hours for fridge to get cold. Is the freezer OK?
Fonzie
Old 01-31-2015, 07:42 AM   #3
Ashley's Avatar
When you say it "Turns On" what do you mean? The light indicating "Auto" mode illuminates? Or you are actually hearing the igniter spark and then the sound of the propane flame indicating ignition actually occurred and there is a flame heating the liquid tank?
Does yours have the option of selecting "Gas" only by depressing a button or do you only have the "Auto" option?
Does the "Check" lamp come on after a few minutes?
Are you hooked up the shore power while you are checking for propane operation?
And, as previously asked, have you given it sufficient time to start feeling the effects of cooling down?
All of this information may help someone here help you.
2008 Dodge Ram 3500 MegaCab 6.7 Cummins
4x4, 4.10 Gears, 68RFE Trans
2012 Primetime Lacrosse 318 BHS
Ashley is offline   Reply With Quote
Old 01-31-2015, 07:54 AM   #4
KyDan's Avatar
What he said plus--
does it cool on electric?
Have you visually verified that it's actually got a flame on LP mode?
Age make and model would also help.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 01-31-2015, 10:44 AM   #5
Jjs2000z's Avatar
I am dry camping in Glamis. When I turn on the fridge on auto, I hear the propane spark and hear flame burning. I turned on the fridge last night and 10 hours later fridge and freezer are warm.
2014 stealth 2714
Old 01-31-2015, 10:44 AM   #6
Jjs2000z's Avatar
Name:	ImageUploadedByForest River Forums1422722687.266588.jpg
2014 stealth 2714
Old 01-31-2015, 10:59 AM   #7
Ashley's Avatar
Well, based on that information, in my opinion, which may not be worth much, you have a major issue that is not gonna be resolved with a quick fix out in the field.
Someone else here may have a different outlook, but it would seem to me if you have the burner working/heating and you're not getting the cooling effect/heat exchange then there is a problem that could be major repair time.
Did it cool at home on electric before you got out on your camping trip?
Have you smelled or saw any type of ammonia leak?
Old 01-31-2015, 11:02 AM   #8
Flybob's Avatar
Is your unit level? Is the Flue hot?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-31-2015, 11:08 AM   #9
Jjs2000z's Avatar
We leave our trailer in storage out here so do not know if unit works on electric. Hopefully this will be covered under the warranty. I pushed the second year warranty when we bought this trailer.
The trailer is level
2014 stealth 2714
Old 01-31-2015, 12:25 PM   #10
fonzie's Avatar
Have you checked your battery voltage with a multimeter...need to be above 12 volts for proper operation....Is propane supply adequate?
Here is manual in case you don't have...
http://www.manualslib.com/products/D...2-2821469.html
Fonzie
dometic
