Old 08-07-2014, 12:53 AM   #1
Emptying the gray tank.
When I pull the handle for the black tank it flows with a big woosh. The gray tank flow is about half the speed and takes a few minutes to drain 2/3 full tank. Is this normal? Anyone experience this. I have a 2015 SA2515G.
tb83 is offline   Reply With Quote
Old 08-07-2014, 02:00 AM   #2
mlangdn's Avatar
Yes, that's normal for me too. The grey tank drain line is half the size of the black tank. If you look under where both enter the Y for draining you will see the difference.
2014 Coachmen Catalina
243RBS 50th Anniversary
2013 F250 Lariat 6.7 Powerstroke
mlangdn is offline   Reply With Quote
Old 08-09-2014, 05:04 PM   #3
Jjs2000z's Avatar
Yes that is correct. The black tank flow will be a lot faster due to the larger piping.
2014 stealth 2714
Jjs2000z is offline   Reply With Quote
Old 08-09-2014, 07:17 PM   #4
Right on thanks guys.
tank
