Old 08-25-2019, 04:30 PM   #1
Fresh water hose leak
All,
I have a 2313 toy hauler with a water leak under the trailer.
This hose is located on the driver side right next to the two tires, between axels.
It appears to be a pvc 1.375" marked hose, approximately 14" long, connecting the two tanks, I believe.
The one forward clamp broke while in transit and poked a small hole in the hose, causing a small leak on the line. I replaced the clamp and the drip slowed but not stopped.
I think it would be best to replace the line, as it is a short length. Anyone know a replacement part for this? I have found locating a 1.375" hose is more difficult than I imagined. 1.25" is easy. 1.375", not so much.
Thanks for any advice.
2016 WA2313 Stealth
2018 GMC Sierra 3500 HD Denali Crew Diesel SWD
2006 & 2009 Honda CBR1000RR & 2018 CB1000R
2016-present nights camped: Too many to count
Bigb49 is offline   Reply With Quote
Old 08-25-2019, 04:37 PM   #2
Brake is on left
The Evil Twin's Avatar
Is rhis what you are looking for?
https://hosewarehouse.com/products/f...duct-hose-50ft
The Evil Twin is offline   Reply With Quote
Old 08-26-2019, 01:05 AM   #3
Yes, that looks like it!! Thanks
Do you know the function of that tube? Is it a connection between the fresh tanks?
Originally Posted by The Evil Twin View Post
2016 WA2313 Stealth
Old 08-26-2019, 11:31 AM   #4
Brake is on left
I suspect it is an equalizer line if you have 2 fresh tanks. It would allow water to flow between the two. There would also be one on top of the tanks (maybe smaller in diameter) to allow air to move between the tanks. I only have a single 110 gallon tank. I do have that same tube going from the fill connection to the tank though.
Old 08-26-2019, 01:32 PM   #5
I was thinking the same thing.
Thanks for the link and replies. Appreciated. Keep the rubber side down!
2016 WA2313 Stealth
Old 08-26-2019, 03:45 PM   #6
Maybe...
Maybe the OP could call them and get the name of a local retailer or distributor who would sell it priced by the foot.
The source above isn't too expensive--less than a dollar a foot--but they don't seem to sell less than 50 feet at a time.
Larry
Larry-NC is offline   Reply With Quote
fresh water, leak, water
