Old 06-23-2016, 12:40 PM   #1
Question Fuel pump
We purchased a 2016 stealth ss1913 from a private party who knew nothing about it because they never used it. We are trying to figure out the fuel system. Can anyone out there tell us where the fuel pump switch is? We found the timer inside on the control board but find no instructions on the operation. Thanks
Clemons is offline   Reply With Quote
Old 06-23-2016, 03:48 PM   #2
On the last unit I had (not Stealth) it had a main power switch by the front door/control panel and one by the pump mounted to the frame.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 06-23-2016, 03:52 PM   #3
15 minute timer switch inside and should be a toggle switch outside by fueling station on frame.
guyster is offline   Reply With Quote
Old 06-23-2016, 04:26 PM   #4
Fuel pump
Thanks for the info Will check that out
Old 06-23-2016, 04:42 PM   #5
Cool Fuel pump
Super, thanks so much found the toggle switch. Looked in all the wrong places. Since it was black, husband didn't see it.
pump
