Old 02-08-2016, 12:38 AM   #1
Generator
Had the 2016 2313 Stealth out for 2 trips already. Was out cleaning the rig from the last trip today. Started the Generator to use my Vacuum cleaner and also break in the generator by putting a load on it. After using the Vacuum cleaner i turned on the air conditioner. It ran for about a minute. Then it lugged down the generator to the point where it caused it to shut off. I tried it 2 more times and the generator did the same thing? Anyone one have any ideas what could be causing the problem? I had the trailer out the week before and had the air conditioner running for an hour with no problems? Any help would be great.
mkccmc is offline   Reply With Quote
Old 02-08-2016, 02:24 AM   #2
John McClain's Avatar
What size is your Gen. ?
What size is your AC. ?
and your Vacuum
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
John McClain is offline   Reply With Quote
Old 02-08-2016, 10:52 AM   #3
Onan 4000
Vacuum cleaner standard house vacuum
AC is the standard one that comes on the 2016 2313 Stealth.
Old 02-08-2016, 11:46 AM   #4
Who Dares, Wins
doc73's Avatar
Not the same trailer.. But my parents have a Sunseeker with 4k onan. Theirs will trip quite easily when using the A/C and a few other items, esp the micro. Could just be too much for the trailer to be using all at once. Was the converter on as well to charge up things? They can draw some juice when they are up and charging.
Pat, Jen & Heather... Oh yeah and our trained attack trailer cat, Cinnamon-EOW 11/22/2017
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 02-08-2016, 12:07 PM   #5
Flybob's Avatar
AC is about 13A running ( higher on compressor start) and most full size household vacs are 10-12A. 25A for these tow alone. Then you have the converter and a few small things. so you could be close. Remember when the generator lugs the voltage drops and the appliances draw more current which could trip the generator protection circuitry.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-08-2016, 03:15 PM   #6
Yeah I don't think generator strong enough to do both. At no time were both running at the same time and like.
Old 02-09-2016, 03:02 AM   #7
AMG
If you have the electric hot water heater switch on too, that is a lot of amps. And yes, I ran in to this on my old coach that when the converter detected low DC power from the batteries and switched that on to charge them, that like 13A for that, plus the A/C, plus the Elec. hot water, was too much.
Otherwise, if that isn't your problem, of course look to taking it in to the dealer then, that's why you have the warranty.
TH : 2016 Stealth WA2916
TV : 2012 Ford F-250 PSD
AMG is offline   Reply With Quote
Old 02-09-2016, 07:22 AM   #8
TURBS's Avatar
This may help you figure your electrical loads.
normal appliance amp draws
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
generator
