Old 05-12-2014, 08:13 PM   #1
How to access bypass valve.
I just bought a used Stealth 2612 and I cannont find a way to access my HWT bypass valve. Does anybody know how to access this on my model unit?
contagius is offline   Reply With Quote
Old 05-13-2014, 11:59 PM   #2
I have a 2011 2612 and it's located down below the storage thing to the left side of the bed. There's 4 screws you take out to remove the cover and there's 3 valves there.
msteeler is offline   Reply With Quote
Old 05-14-2014, 09:06 AM   #3
Thank you. I found it. There is also access through the pass through storage area from outside the trailer.
Also does yours have a water filter? I cannot seem to find one anywhere that would be easily accessible.
Old 05-14-2014, 09:27 AM   #4
I had a water leak so I've been all through this trailer. I've never seen a water filter but you could probably install one under the sink. We just use the water for showers and to wash dishes.
Old 05-14-2014, 09:46 AM   #5
I have tried to find a place to get under the sink and cannot figure out a way aside from tearing stuff apart. Is there an easy way to get under there?
Old 05-14-2014, 03:09 PM   #6
Yeah it's pretty tight under there. Maybe you could install it in-line between the fresh water tank and the water pump under the trailer? Not sure if that's a good idea or not.
Old 05-14-2014, 04:29 PM   #7
Probably wouldn't want to put it in the suction line. That may cause damage to the pump if it has to pull harder.
One more thing I am not sure about is if the water heater will run off of electricity as well as gas. Do you have an answer for this?
Thanks again and sorry for any inconvenience.
Old 05-14-2014, 07:52 PM   #8
I'm not sure if they changed from year to year but on my 2011 both furnace and water heater are gas only.
Old 05-18-2014, 11:23 AM   #9
Jjs2000z's Avatar
My 2014 WA2715 water heater and furnace are both gas as well
2014 stealth 2714
Jjs2000z is offline   Reply With Quote
Old 05-18-2014, 11:30 AM   #10
Ford Idaho's Avatar
Something like this perhaps?
bypass
