Old 07-08-2015, 12:18 AM   #31
Originally Posted by mike.t View Post
So how does one replace/reverse the one way check valve?
"Back and forth flushing while looking at the tank gauges continuously and using a flashlight shining in to make sure nothing goes wrong?" Your a hoot SULTINI
Well Mike,t.
Our black tank flush pipe work runs upstairs to the bathroom sink cabinet, then runs back down to the black tank. So up under the bathroom sink cabinet is where the check valve is. That is where all the water was leaking from. The dealer literally unclamped the pipe and switched the connection around.
Hope that helps.
barrie1 is offline   Reply With Quote
Old 07-08-2015, 05:56 AM   #32
Mike T, Let me explain my post. I stated that I do the flush exactly like Campster does in post #2. Then I was done with the auto flush porcedure. Then I went on to explain how I fill my Black tank and then dump it without the built in tank flush. I was just explaining the fill and dump procedure before the auto flush is used. Sorry if I didn't explain it in two separate answers. FYI my auto flush works great. Happy Camping.
PS: I'll bet you liked the piece of wood to keep the toilet flushing.
2010 FORD F 150 5.4
#1-18' Nomad #2- 20' Mallard #3- 27' Sunline #4- Four Winds C #5- Innsbruck 40' PARK # 6- 28' Amerilite #7- Forest River 26.5 FW ( 1st FW)
SULTINI is offline   Reply With Quote
Old 07-08-2015, 05:57 AM   #33
Wolverine 1945's Avatar
Sorry. "Used it once in the driveway... water ran clear" You dumped the black while the RV was in the drive way and the black tank flush worked as expected?
We had dumped @ a dump station a few days early,,, and then I tried the Black flush @ home,,, I could not flush it @ the dump station because the flush is on the other side,,, MH was almost new then !!! I guess it was working ???
I am planning from here on,,, to do like one guy said,,, I am going to carry some GEO with me,,, so it can be sloshing around while we are on our way home !!!
Wolverine 1945 is offline   Reply With Quote
Old 07-08-2015, 11:37 AM   #34
mike.t's Avatar
barrie. Thanks i'll give that a look.
SULTINI.I was saying to myself that must be a heavy piece off lumber.;o)
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
tank, black
