Old 07-05-2015, 07:55 PM   #1
How to use the black tank flush??
We just bought our first Toy Hauler a 2014 Stealth WA2313. Just coming from our first trip out and trying to dump the grey & black. We got both tanks emptied but can't figure out how to use the black tank flush? So, we flushed the toilet several times until the black tank ran clear. Does anyone know how to use the black tank flush?
Thank you in advance..
Jaynlisa5 is offline   Reply With Quote
Old 07-05-2015, 08:17 PM   #2
Campster's Avatar
With your black tank dump valve open connect a hose form the water source to you black tank flush inlet. Turn the water on and the flush will rinse/flush out your black tank. If you have a clear elbow on your sewer connection you will see it run clear. Not that difficult. Just make sure you have the dump valve open so that the toilet does not overflow from the inside.
Campster is offline   Reply With Quote
Old 07-05-2015, 10:51 PM   #3
We did that setup like you described but when we turned the water on it started to leak through our furnace vent in side. Also, we never saw water come from the sewer hose. Do we need to have our water pump or generator on?
Old 07-05-2015, 10:58 PM   #4
elrand's Avatar
Sounds like another check valve improperly installed. No you don't need the gen or wp on. You'll have to check the plumbing behind where you hook up your hose
2015 Cedar Creek Silverback 33IK
elrand is offline   Reply With Quote
Old 07-06-2015, 08:58 AM   #5
Ok, will check that next. Fingers crossed it's a simple fix. Thank you!
Old 07-06-2015, 09:05 AM   #6
Pauls Toy Hauler's Avatar
Hopefully you get it working soon. We absolutely love our black tank flush option.
2015 Palomino Puma Unleashed 351-THSS 37' Toyhauler
2016 F-350 Platinum DRW 4x4 w/ Curt Q24 hitch and Air Lift rear air ride
"Just put that hammer down and give it hell" -Jerry Reed
Pauls Toy Hauler is offline   Reply With Quote
Old 07-06-2015, 12:51 PM   #7
black tank flush
do not leave the hose on black tank flush when not in use, because some idiot might turn it on with black tank closed. Don't ask me how I know this��.
NorSnrub is offline   Reply With Quote
Old 07-06-2015, 12:51 PM   #8
mike.t's Avatar
How do you do that?
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 07-06-2015, 12:57 PM   #9
MartiB's Avatar
I just bought a 2015 Salem CruiseLite 241QBXL. Does this have the black water flush inlet mentioned? If so, where would I find this?
MartiB is offline   Reply With Quote
Old 07-06-2015, 01:15 PM   #10
mike.t's Avatar
It is a hose connection located above the dump valve and say's "Black tank flush". I don't think yours comes with one.
2015 Salem 27RKSS
55' Chevy Bel-Air
tank, black
