Old 09-17-2015, 05:51 PM   #21
Taranwanderer's Avatar
I'm still in shock that a dude from Cali used the word "cattywompus" (PA spelling) correctly in a sentence!
Seriously, good luck with the door, that is messed up. I think my next trip would be to IN...
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (‘18)21 (‘19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 09-17-2015, 05:52 PM   #22
ryanq55's Avatar
A closer shot
2015 Stealth WA2916 Toyhauler
2007.5 Dodge Ram 2500 6.7L CTD
ryanq55 is offline   Reply With Quote
Old 09-17-2015, 05:56 PM   #23
ryanq55's Avatar
Hahaha...actually heard it from a guy I was working with who was from Arkansas!!! When he said it I looked at him like WTF just happened???
Old 09-17-2015, 06:21 PM   #24
ryanq55's Avatar
Polarisguy & AMG, heres some photos of the underbelly...
-The 60gal with the single support underneath thats already bowed pretty bad
-The tube between the two tanks to transfer the water into the additional 60gal...which i think i may bleach the tanks or clean them somehow and replace that hose with a black one seeing as the clear tube letting light in looks like it allowed algea to grow already You can also see the gray filler tube up above, behind the wiring in the pic
-The 100gal with the drain valve which seems to be mounted in the pretty stout with like 3 supports (you can see how the trailer brake wires just kinda flop around too...wanting to clean that up)
-The underbelly looking towards the front with all the wiring I want to clean up...even thinking of maybe re-running the LP line straight down the middle and T'ing off from there to the water heater and quick-connect/fridge line to get it away from under the fram rail on the one side.
ID:	89013   Click image for larger version
ID:	89014   Click image for larger version
ID:	89015   Click image for larger version
Old 09-17-2015, 07:42 PM   #25
dieselbobcat's Avatar
In addition to a lockwasher, you need some thick fender washers on there to get maximum friction when torquing down... get some grade 8 or 10 cut washers (they will be much stiffer and thicker than grade 5... they have a yellow oxide finish to them...) and slip them in with a serrated or lock washer.
I would personally swap all the hardware for grade 8 if it has been repeatedly fooled with by the dealer...
2021 Cedar Creek 37MBH
2020 F350 Powerstroke Super Duty Lariat Crew Cab
Northern NJ - God Bless America!
dieselbobcat is offline   Reply With Quote
Old 09-17-2015, 11:14 PM   #26
PolarisGuy's Avatar
Awesome post dude! And yeah, makes me think of a lot of things....
A. Glad we all paid 40k for our 35' toy haulers to spend our weekends fixing SH**!!
B. Gave me some good ideas especially about that nasty algea in the tube lol.
C. Had been wanting to mention the break lines. Now it just made me remember!
RV: 2016 Stealth WA2916 Toy Hauler
TV: 2005 F250 PSD
2012 Polaris Sportsman 850XP
2014 Brute Force 300 (daughters)
2016 Days Camped: 22
Check Us Out On YOUTUBE!!
PolarisGuy is offline   Reply With Quote
Old 09-24-2015, 10:51 PM   #27
ryanq55's Avatar
ramp door problem solved...i think
So after tinkering around with my ramp door that seems to just not be able to hold a constant position, I discovered this...
The holes of the hinge that bolt to the "bumper" plate are actually just shy of 1/2", so the 3/8" bolts slop around quite a bit
The "slotted" holes in the bumper plate had no washers on the backsides behind the nuts, which leads me to believe with bouncing down the road they moved quite a bit and werent able to really grasp a flat surface.
After muscling around with a pry bar to finally center the door i was able to discover the first curbside set of slotted holes didnt even line up with the hinge holes, which in turn automatically offset my door to the curbside, giving me the gap on the roadside...........if that makes sense
Soooooooo, im going to replace the 3/8'' allen bolts with hex head bolts, because I stripped 3 trying to take the damn things off.
Re-drill the last holes for the hinge to line up correctly, and im going to use serrated flange nuts and hope that locks the door in place and stops it from moving around.
If that doesnt work, I will try switching to 1/2" hardware....
If that doesnt work I will probably blow my trailer up
ID:	89802   Click image for larger version
ID:	89803   Click image for larger version
