Old 04-28-2015, 11:16 PM   #1
Just got it home 2015 stealth 5er
My orientation went well but I have a few questions like when boondockin how often do you guys recommend running the generator set? and is there ever a need to run the generator while hooked up to a 50 amp site? This is my first RV with a generator only my second ever the first was a pop up. so I can use all the advice I can get
doitdaily is offline   Reply With Quote
Old 04-29-2015, 06:23 AM   #2
TURBS's Avatar
No need to run gennie while hooked to shore power.
While boondocking run gennie everyday to recharge batteries as needed.
Do not allow batteries to discharge to deeply or the life of batteries will be reduced significantly.
50% discharged is considered dead.
Good luck and have fun!
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-29-2015, 08:13 AM   #3
Jjs2000z's Avatar
Does your trailer have solar on it?
2014 stealth 2714
Jjs2000z is offline   Reply With Quote
Old 04-29-2015, 09:48 AM   #4
Yes, it is equipped with solar. Am I right in thinking I only need to run gen. when batteries get to 50% and when I need to run the a/c's and microwave? Solar seems to keep the batteries well charged and the fridge automatically switches from ac to propane when the generator is off. I want to use the gen. because an unused gen. is a faulty generator. Should I run it a couple hours a day just to keep it worked out?
Old 04-29-2015, 12:18 PM   #5
Just remember if the Batteries are dead them you can't start the Generator unless you charge them up with your truck.
The solar is great, we love ours. As you know it doesn't work at night.
Have a good time.
barrie1 is offline   Reply With Quote
Old 04-29-2015, 12:32 PM   #6
NYDP77's Avatar
If you decide to dry camp at a campground with no hook ups just remember to check for rules on generator. Some campground have certain times or they may not be allowed.
DP
2013 Tracer 240 AIR
2014 Silverado 1500
NYDP77 is offline   Reply With Quote
Old 04-30-2015, 11:09 PM   #7
Jjs2000z's Avatar
You only need to run the gen 1-2 hours per month. I run two energizer 6 volt gold cart batteries and they work the best!
2014 stealth 2714
5er
