Old 01-21-2016, 03:25 PM   #1
Leaking front bedroom window
I have a 2015 SA2515G and I went to the trailer today to run the gen and check up on everything. The head of our bed was soaking wet with water stains and mold across the the whole width of the bed. I suspect it's that weird pop out window. Has anyone had this issue.
Thanks Travis
tb83 is offline   Reply With Quote
Old 01-25-2016, 12:11 AM   #2
AMG
Are you positive it was closed tight? I made this mistake once, luckily it didn't rain and I noticed it the next week at my storage facility.
No, not me. It should be easily diagnosed though (if that is the issue) as you can very easily get to that from the roof to check the seal, then of course spray water on it and look for leaks if it isn't obvious before.
"they" say that roof leaks are super common in trailers. Yearly you are supposed to get up there and inspect all the sealant and replace a lot of it as preventative measure -before- a leak occurs too.
TH : 2016 Stealth WA2916
TV : 2012 Ford F-250 PSD
AMG is offline   Reply With Quote
bed, leak, roo
