03-09-2014, 10:25 AM
LED package doesn't have leds?
I just got a 2612 and one of the add-ons was the solar panel with interior LED package. The under cabinet lights are all LED, but all of the ceiling lights are not. Is this a mistake? Can somebody with one of the current models with the LED package check their trailer? I was thinking the whole interior was supposed to be LED.
Thank you,
John
03-09-2014, 11:43 AM
chicagoslick
Not sure which unit you have, but my 2014 Flagstaff 27RLWS came with all LED lighting except the orange outdoor light. They told me a reason for it, but I do not recall. Post more info about your unit/....
Gary, Tonia, Baile, Summer and Otis our Boston T.
Flagstaff 27RLWS Emerald Pkg
2015 Ford F150 King Ranch FX4 Max Tow 3.5EB, 3.55
Equalizer 4 WDH, 1,200 / 12,000Lbs
03-09-2014, 11:45 AM
It is a 2014 stealth 2612 toy hauler.
03-09-2014, 05:46 PM
My 2013 2715 has the solar and LED package. Just like yours only the under cabinet lights are LED. They do put out good light though. And the solar panel is worth it's weight in gold.
03-09-2014, 07:07 PM
It's not a mistake that's the way the trailer is. But for about $3.50 per bulb you can replace them with LED's and upgrade the batteries to two 6 volts and you will never run out if power.
2014 stealth 2714
03-09-2014, 07:16 PM
I already have the two 6 volt batteries. I am going to get the leds fir the rest. Thank you guys!
03-09-2014, 07:19 PM
Get These led lights from eBay. They are the exact same color as the stock bulbs.
2014 stealth 2714
04-28-2014, 12:30 PM
My trailer has the LED lighting package. Know what that consists of? The lights up front used to hook up the trailer. They are LED. Other than that, everything is incandescent.
Not sure why they wouldn't make the exterior light LED, aside from weather issues. LED lights put out zero UV light, meaning that bugs are not attracted to them. CFL, incandescent and halogen all put out UV light. I replaced all the bulbs in the trailer with pretty good ones, which cut the power usage drastically. I measured that each of the T10 bulbs were using 25 watts. The LED bulbs put out fewer lumens (I measured with a light meter), but only use 1.5w. Yes, that's right, the incandescent bulb uses more than 16 times the energy the LED bulbs do. When boondocking, lights and furnace fan are the largest consumers of power. Now almost all the lights in the trailer equal one of the old bulbs, lol.
I also tested the furnace fan, and it used about 115w.
TV: 2018 Ford F-350 Powerstroke
Trailer: 2013 Palomino Puma 27SBU
04-28-2014, 02:21 PM
I list say it is mis leading , but $30 in led interior lights aren't worth arguing about. I must say, the solar panel and 160 gallon fresh water tank are by far the best upgrades on the market right now. These two features are what made me switch from eclipse to a forest river product.
2014 stealth 2714
07-28-2014, 10:26 PM
Just got a WA2715 with the solar and LED package. With exception to the running lights and undermounts the rest are incandescent. That's getting changed this week when I at least swap all the interior and entry with LED. Will leave the scare lights alone.
The LEDs weren't the seller anyways, it was the solar.
With that said, I was first under the impression it was a full LED swap as well until I really looked at the roof lights then reread the option. Dealer didn't help either by claiming it was all LED...
07-28-2014, 11:14 PM
Location: Alberta - East of the Rockies, West of the Rest
Isn't that cool, we changed the whole house over to LED's last winter - no bugs and our trailer has all LED's, no bugs either, guess they're out visiting the neighbours .
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
07-28-2014, 11:35 PM
Our 2014 Wildcat Maxx is all LED as advertised. We also like the blue tooth touch screen control unit that handles the slide, f & R stabilizers & awning.
I'd be very upset with my dealer ( as well as FR if it was shown to be LED in the brochure)if I was told my trailer was totally LED only to find out the LED's were present in a few isolated spots. That's just not right!!!!
07-29-2014, 12:13 AM
The problem isn't that it was advertised as full LED, just that it was easily missed that it was the undermounts and running lights only.
Now, the dealer should have known better...
07-29-2014, 09:51 AM
I agree it is misleading, however changing out the led's are around $3 per bulb. We'll worth it
2014 stealth 2714
07-29-2014, 10:52 AM
What bulbs did you go with?
07-29-2014, 11:02 AM
Put blue led strip under awning and we had all kinds of bugs , led's didn't keep them away for me. Also still got them inside and had changed all inside lights.
Think about things before you do them make life easier not harder.
07-29-2014, 11:13 AM
There is no difference in quantity of bugs "visiting" with leds
