Old 09-03-2014, 02:01 AM   #1
ryanq55's Avatar
New here with a WA2916
Hey everyone,
New here, just purchased a 2015 WA2916. suppossedly a 29' even though the overall box length is 35'?? Where do they even get 29' from? Any ways, happy to be here, excited to take the family out for the first time. We love to go from the mountains to the deserts, and even to the beaches....Southern California has it all! Looking for some mountain areas to boondock and explore with my Wildcat 1000 4 seater. Anyone know of any good areas to recommend?
ryanq55 is offline   Reply With Quote
Old 09-03-2014, 08:08 AM   #2
Welcome and congrats on your 2015 WA2916. The 29 probably comes from the interior closed length and the 35 is the length when opened up in the back.
Old 09-04-2014, 06:05 PM   #3
Jjs2000z's Avatar
I believe that's livable space. My WA2715 is about 33ft from front to back.
2014 stealth 2714
Jjs2000z is offline   Reply With Quote
Old 09-06-2014, 09:58 PM   #4
ryanq55's Avatar
Just pulled this beast home. Ended up purchasing the Equal-I-Zer 4 way sway control WDH...this thing was planted right behind me. No just to drive it around town a little and get comfy with this length. Any input on temperatures I was getting while climbing the hill to get it home? I've read it's about a roughly 10 mile long 3-4% grade at about 100*F...I've got a 2007 dodge ram 2500 6.7l cummins with 35's and I was pulling about 8500lbs at about 55mph......my trans fluctuated about 195-199*F and the coolant was a steady 215*F...
Old 09-07-2014, 12:34 AM   #5
Jjs2000z's Avatar
When I towed with my f150 the trans temp went all the way to yellow and almost hit the red. You should be ok.
2014 stealth 2714
Old 09-07-2014, 09:39 AM   #6
ryanq55's Avatar
Oh yea that's not good...hah...what do you tow with now? Yea I was taking it up the cajon pass. I feel like my trans just runs abnormally hot for some reason. Don't know if your familiar with some of the roads up here but I took my enclosed trailer with my wildcat (only about 5k lbs) up to miller canyon, and going up the 138 (which is a shorter stretch but some of those little grades seem literally twice as steep) my trans ran up to 240*F. It was about 100*F that day too, and when I saw 240* I just about $h!t a brick, pulled over and let it cool down. I've since then changed fluid and filters and installed a mag hytec trans pan and rear diff cover. I see 1/2 ton trucks blasting through there towing good sized little boats all the time, makes me wonder if they're cooking the trans and just don't know it???
Old 09-07-2014, 09:45 AM   #7
Jjs2000z's Avatar
I love in southern Cali also. If you are overheating up the cajon with that small trailer you will definitely have a problem towing a toy hauler up the pass. I recently scooped up on a 2014 F250 diesel, and boy I am glad I did! This thing is a beast! Click image for larger version
Name:	ImageUploadedByForest River Forums1410101128.875456.jpg
2014 stealth 2714
Old 09-07-2014, 11:25 AM   #8
ryanq55's Avatar
I didn't heat up going over the cajon I heated up going over the 138 which is 2x as steep as the cajon and winds back and forth. I probably averaged 20 mph so I'm guessing lack of air flow didn't help the trans temp situation either.
Old 09-07-2014, 11:41 AM   #9
ryanq55's Avatar
Pic
Old 09-07-2014, 11:00 PM   #10
ryanq55's Avatar
So I'm loading up the trailer and realize that the bedroom door opens during transit, the bedroom drawers don't stay shut, two kitchen drawers don't stay shut and one guide broke (a different guide was broken already and they fixed it during my walk through) the bunks in the back have a loose connection at the module that disgustingly tackily hangs from the back corner of the trailer (they wouldn't go up when I did the walk through...they fixed it...and now they wouldnt go down till I wiggled the module around) and the ramp door seems to be tweaked...I can see light around the edge of one of the corners... Hopefully my dealer won't make these foxes too painful, I plan on taking it out next weekend...
