Old 05-13-2014, 12:55 AM   #1
Area 52's Avatar
New Stealth for us
We recently traded our smallish Sandstorm for a much larger WA 2715 Stealth. After two months we are happy with the Stealth but have run across a few issues worth sharing. After delivery I found several lug nuts improperly torqued, one that was broken, making me glad I checked before that first trip. On arrival home after our latest trip the entry door deadbolt would not accept the key so I opened the ramp and tried to unlock the deadbolt with the red handle. No luck so a new lock is ordered. When I opened the ramp I was shocked to see my Triumph Bonneville lying on its side. The D ring on the right front failed and the rear strap did not hold. Only one small scratch thank goodness! Even though I never had any problems with the D rings on the old trailer I am looking at replacing all of them with higher rated D rings. Lastly when I was in the forward cargo hold I looked up and noticed one of the floor support beams under the bed was broken and hanging down a couple of inches. (it broke on a knot) That plus a couple of fit and finish items has me wondering about how well the unit is checked before leaving the factory. I have crawled all over and under the unit not finding any serious issues. These are all minor and we are very happy overall.
Area 52 is offline   Reply With Quote
Old 05-18-2014, 11:22 AM   #2
Jjs2000z's Avatar
That sounds like a good unit except for the lug nut situation. We love our Stealth WA2715. The best trailer we have ever owned.
2014 stealth 2714
Jjs2000z is offline   Reply With Quote
Old 06-26-2014, 10:30 PM   #3
Area 52's Avatar
Just a quick update / warning about the Tie down D ring. It turns out it was only secured by 2 short wood screws most likely due to the water tank below. I am fitting up-rated tie downs about 6 inches aft and writing a memo to Forest River suggesting they take a look at their installation practice. We are enjoying our Stealth but missing the motorcycles until the fix is complete.
2013 F-150 Ecoboost
2014 WA2715 Stealth
Old 06-27-2014, 12:56 PM   #4
stealthWA2313's Avatar
Area 52. Just curious, how does the F150 handle your 2715? We have a 2313 and have thought that we would like to eventually look into downsizing to an F150 when it comes time for a new truck. With the costs of the new diesels, I just can't justify paying that kind of money for the level of towing we are doing.
My main concern would be with the tongue weight. Ours is around #1000, but we do not haul toys or much water (20 gallons).
Thanks,
'17 F350 STX 6.7 CCSB
'15 Stealth 2313
stealthWA2313 is offline   Reply With Quote
Old 06-27-2014, 01:12 PM   #5
Jjs2000z's Avatar
I am towing my 2715 with my 2012 F150, it tows the trailer fine. If your towing in mountains I would probably look at a diesel
2014 stealth 2714
Old 06-27-2014, 05:21 PM   #6
Area 52's Avatar
My F-150 has done a stellar job towing the 2715. It took a long time to convince myself that the F-150 could do the job when I was shopping trucks. I have towed mostly in the west, most recently Idaho, with lots of hillclimbs. I spent a lot of time running the numbers beforehand and would caution anyone else to do the same. I made a sheet with the limit weights in the first column and estimated weights in the next. Even after I bought the 2715 I created a third column for actual weights. It takes some effort but is definitely worth the time. The F-150 has lived up to its numbers.
2013 F-150 Ecoboost
2014 WA2715 Stealth
Old 06-27-2014, 06:38 PM   #7
I figured the Eco Boost would do fine pulling the weight, just the cargo capacity would get kinda tight. I may just keep my truck until it dies. I have had it since it was new and have had no problems with it. It is however a 6.0 and most people say it is not a question of if, but when, the head gasket and oil cooler decide to go. I have 124,000 on it with no payments, so it would probably just make sense for me to eventually spend 6-7 grand for the bullet-proofing of the engine than to buy new.
Thanks for the info.
'15 Stealth 2313
