Old 04-21-2012, 01:04 AM   #101
TURBS's Avatar
do you ever bleed the hw heater with the pressure relief valve ? do it cold please !
also check to see if you have a little strainer with a screen in it by your water pump .
check the tightness of the strainer cup .
check to make sure your low point drain caps are tight .
Old 05-17-2012, 08:24 PM   #102
Send a message via Skype™ to toshu
Originally Posted by jkalafus View Post
We did not have the option on ours, but do carry one of theses in the coach now. Very useful.
12.5 Foot Telescoping Ladder by Extend A Step
I was curious about the ladder and how easy is it to use getting up and down from the roof???
Is it tall enough for that???
-2009 Ford F-150, SuperCab w 8 ft bed
5.4L Screw, 3.73 rear, 8200 GVWR
-2011 Rockwood 2604, 2x6V Interstate U2200 batteries,Yamaha 2400 genny
-2011-23 nights
toshu is offline   Reply With Quote
Old 05-17-2012, 10:45 PM   #103
I have one for our rg3210 with a 3inch lift. It is not tall enough. I would think a 15' ladder or taller would work. I have not seen any that are compact and light that are that tall.
KJandRNii is offline   Reply With Quote
Old 05-18-2012, 09:26 AM   #104
Ours is perfect. Bows a little as you go up(I'm 200Lbs) and careful when you collapse it down so you don't pinch fingers, but I think it works great.
jkalafus is offline   Reply With Quote
Old 05-18-2012, 09:34 AM   #105
What is your trailer height???
Mine is 118 inches
-2011-23 nights
Old 05-19-2012, 07:40 AM   #106
I have a question about charging the batteries when connected to the rv, does it matter if the 12v disconnect key is plugged in when charging from an outside source?
emangle is offline   Reply With Quote
Old 05-19-2012, 11:08 AM   #107
Mine is 118 inches
Ours is 143 from roof to ground.
Old 05-19-2012, 01:01 PM   #108
Drinkin beer on the beach
Rod Johnson's Avatar
Thats a good question. I suppose any trailer can be wired up any way.
My batteries are connected to the bargman connecter even when the shutoff switch is disconnected.
Plugged into my truck, the batteries will charge from the truck regardless of switch position.
Plugged into shore power, my batteries only charge with the switch in the on/closed position.
2014 Silverado 2500 6.6L TD and 4X4
2011 Carson Standard Duty Car Hauler
2012 Forest River Stealth SK2112
Rod Johnson is offline   Reply With Quote
Old 05-20-2012, 08:30 AM   #109
Rod, thanks for the info.
Old 05-27-2012, 09:55 AM   #110
Anyone notice the floor getting fairly warm in front of the heater/micro when heats on? I am wondering if I have a leaky heater vent hose or if it's normal.
210, 5th wheel
