01-09-2013, 06:13 PM
#121
I haven't posted in a while, I have a update I thought I would share. I had a 2003 F250 that pulled it okay for two years. In September I purchased a 2012 F350 DRW, I can't wait to take the RG3210 out next month.
The camper is still going strong and still loving it. Right now my mother-in-law is living in it till the end of January. I'm lucky I have a big drive way and the trailer is outside my house. It makes a great guest home.
Forest River 2011 RG3210
2012 F350 CC 4X4 Ultimate Lariat DRW
01-12-2013, 04:09 PM
#122
Originally Posted by Rabidd
I am looking at a RG3210 I have a 2005 Chevy 2500 HD with a 6.0 V8 and a 4:10 rear end would I have any problem pulling this rig? Dealer says no problem but I want to make sure thanks.
I have pulled mine with my Ram 2500 (3/4 ton, diesel) hundreds of miles. I added the Super Springs to my rear axle to help with the pin weight. I have had zero problems!
2012 Stealth RG3210
2011 Dodge Ram 2500 Mega Cab Laramie 4x4
2010 Ford F150 Super Crew Lariat 4x4
02-01-2013, 12:58 PM
#123
Cracks in frame
Just replaced brakes on lx3112 and noticed when pulling off wheels rusty looking cracks on the frame I beam between the wheels in front of and behind the wheels. It is the same on both sides. Called son in law who builds trailers and he looked at it and determined the cracks occurred where angle iron spanned between I beams and cracked from the frame torquing when turning. I have always been super aware of not making tight u turns an in general babying it when towing. Called forest and have been very pleased with their response so far. Have an appointment on Tuesday to get things going. I am constantly checking tire pressure and lubing bearings and can't believe I didn't see these cracks. I suggest everyone out there take peek. In my case these cracks go all the way through the I beam. Will keep you All updated on this issue.
03-13-2013, 09:28 PM
#124
Inadequate welding
Hello everyone,
I thought I would post a couple of pics of a bad weld on one of the beams supporting the fresh water tank. I first noticed this when I heard a loud bang while filling up the fresh water tank. If you look closely at the weld, it looks as if only a spot weld was performed, and during assembly they forgot to go back and complete the weld.
I ended up fixing this issue myself, by drilling two holes through the support plate/frame and fastening with 1/2" bolts.
03-13-2013, 09:44 PM
#125
On my rv the supports are totally not heavy enough to support the 100 gallons that the tanks hold. Both supporting angle irons have big bows as a result of going down the road with at most 50 gallons of water. In a few weeks I will replace with angle iron with appropriate wall thickness. Amazing that you can have an engineered frame and be so far from being heavy enough to use the trailer as you would normally
03-14-2013, 07:50 PM
#126
I did that to a Tahoe transport by over filling my tanks when I pulled the house out water came out for about 2 min. The steele stayed bowed.
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
03-14-2013, 07:51 PM
#127
I just bought a 3210 2013 model so far its work with out a hitch
03-15-2013, 12:37 PM
#128
Congratulations on your new rig, I'm sure you'll enjoy it like the rest of us.
03-15-2013, 12:41 PM
#129
We've made two trips to our favorite camp ground (round trip is 216 miles) towing with new truck.
My 2003 F250 did okay, but I have to admit new truck towed so much easier. I like the B&W hitch, it's easier to work with then my last hitch.
04-15-2013, 08:04 PM
#130
I just purchased a rg 3210 andI also have sportsman xp, do you fit your bikes side by side?
04-15-2013, 10:54 PM
#131
I put My 450 and 400 quads in nose first and the 250 quad in side ways behide them
04-16-2013, 11:30 AM
#132
We do 3- 2 wheelers with the front wheels by the glass door and a quad sideways behind. Check this out, best system I found for bikes etc.
Bolt It On, Serious Racks
04-20-2013, 08:42 AM
#133
I have two sportsman xp's and I cannot load them in side by side , they are too wide. They have to go in sideways in order to fit. As you know these bikes are pretty heavy 700+lbs, so I had to buy a wide floorjack with a rotating platform in order to rotate the bikes sideways when elevated. The process takes me about a half hour to load the two bikes. It's a pain, but thats the only way they will fit.
04-28-2013, 08:53 PM
#134
Can anyone tell me what they have paid for RG3210 they are high here in New Mexico compared to some online sites or other brand toy haulers.
05-19-2013, 01:14 PM
#135
$39.850 with two power vents and solar panels installed
05-22-2013, 11:23 AM
#136
When the RG3210 was brand new at the LA RV show Oct 2010 they were asking 32K. I did notice the last two years it's gone up a lot.
12-17-2013, 08:36 PM
#137
Does anyone know why Forest River discontinued the RG3210?
2012 Stealth RG3210
01-07-2014, 12:37 PM
#138
At the LA RV Show in OCT 13 I noticed they didn't have a RG3210. I talked to the general manager of Stealth. He said they are making some changes, he didn't go into detail. So I guess stand by to be amazed.
01-21-2014, 04:12 PM
#139
I also just found out early 2011 they stopped building them in Riverside. That might explian some of the issues I had with mine. All bugs worked out now but for a while it a trial.
