04-21-2012, 12:04 AM
#101
do you ever bleed the hw heater with the pressure relief valve ? do it cold please !
also check to see if you have a little strainer with a screen in it by your water pump .
check the tightness of the strainer cup .
check to make sure your low point drain caps are tight .
05-17-2012, 07:24 PM
#102
Originally Posted by jkalafus
I was curious about the ladder and how easy is it to use getting up and down from the roof???
Is it tall enough for that???
2021 (Dec) Dynamax Isata 30 FW Xplorer
05-17-2012, 09:45 PM
#103
I have one for our rg3210 with a 3inch lift. It is not tall enough. I would think a 15' ladder or taller would work. I have not seen any that are compact and light that are that tall.
05-18-2012, 08:26 AM
#104
Ours is perfect. Bows a little as you go up(I'm 200Lbs) and careful when you collapse it down so you don't pinch fingers, but I think it works great.
05-18-2012, 08:34 AM
#105
What is your trailer height???
Mine is 118 inches
05-19-2012, 06:40 AM
#106
I have a question about charging the batteries when connected to the rv, does it matter if the 12v disconnect key is plugged in when charging from an outside source?
05-19-2012, 10:08 AM
#107
Mine is 118 inches
Ours is 143 from roof to ground.
05-19-2012, 12:01 PM
#108
Drinkin beer on the beach
Thats a good question. I suppose any trailer can be wired up any way.
My batteries are connected to the bargman connecter even when the shutoff switch is disconnected.
Plugged into my truck, the batteries will charge from the truck regardless of switch position.
Plugged into shore power, my batteries only charge with the switch in the on/closed position.
2014 Silverado 2500 6.6L TD and 4X4
2011 Carson Standard Duty Car Hauler
2012 Forest River Stealth SK2112
05-20-2012, 07:30 AM
#109
Rod, thanks for the info.
05-27-2012, 08:55 AM
#110
Anyone notice the floor getting fairly warm in front of the heater/micro when heats on? I am wondering if I have a leaky heater vent hose or if it's normal.
05-30-2012, 11:02 PM
#111
I just got back from a Memorial weekend trip and had to use the heater quite often. I did notice the same issue with the warm floor in front of the heater/mirco, seems to be normal. The other issue i noticed was the heater vent for the front bedroom barely blows any heat. Do you notice this too?
05-31-2012, 09:22 AM
#112
Yes, I forgot to mention that too. I Took Off the grate and heater front cover, looks like it sends the warm air down into a metal box that splits it off. Looked under the rig and I can't see it. It is in between the floor and a tank/insulation barrier. Well, glad it's not just me.
07-09-2012, 10:30 PM
#113
Been a while since I've posted. wee've done some trips, the latest being a 7 day trip to utah for the 4th. Had some new isues come up
1. Fuel station pump quit on me. Gears locked up. I called great planes and after some serial number and manf date info, they sent me new gears. I installed them and they turn, but no fuel. Can;t get it to prime. Ongoing
2. found a soft spot in the floor just to the rear of the rear personnel door. I have never carried fluids back here, just quads. Guess I'm gonna habve to cut the linoleum and see what is going on. ongoing
3. This is a doozie. The front face of the cabinets over the sliding door fell off while camped in utah. Kids were in there playing cards. Wife was doing dishes. BBBOOOMMMM. I run in and find the entire front of the cabinet on the floor. The whole thing is held on with thin wire staples. It busted the partical board pretty good and gouged through the linoleum. It just missed one of the kids when it fell.
Needless to say I'm not very impressed swith the craftsmanship of the factory guys for the Stealths
07-10-2012, 08:39 AM
#114
We had the fuel station pump issue too. Dealer fixed it under warranty. Was intermittent so it took a few try's for me to see the issue.
Had the same issue with the front face of cabinets after going down a bumpy road. Glad we got the extended warranty. I will have to take it in and make use of it I guess.
07-21-2012, 12:05 AM
#115
Has anyone installed a satalite box in the trailer? If so where did you put it and what do you need to install it? Thanks
07-21-2012, 02:13 AM
#116
Reciever
Dish
Cables
Remote
01-06-2013, 10:39 PM
#117
I am looking at a RG3210 I have a 2005 Chevy 2500 HD with a 6.0 V8 and a 4:10 rear end would I have any problem pulling this rig? Dealer says no problem but I want to make sure thanks.
01-06-2013, 10:50 PM
#118
The overall weight your good but from what i saw the pin weight Is almost 2,700 pounds. That is going to be to heavy for your 2500. By the time you add weight to the trailer and your truck your going to be way over your gross carry capacity of your truck.
2011 GMC 2500HD Diesel
01-07-2013, 08:31 PM
#119
Thanks for the info yeah 2700 is what the flyer states. Is the max pin weight 2500. Does anyone have any suggestions with out getting a new truck.
01-07-2013, 10:13 PM
#120
Camper Less Camping
X2...IMO, consider lighter camper...no add-ons to change weight restrictions.
2013 Sabre 32RCTS-6 (sold)
