Old 04-04-2016, 03:19 PM   #21
Thanks a ton. Dealer keeps saying its a fuse but I can't find any blown fuses????
brandonv is offline   Reply With Quote
Old 04-04-2016, 03:40 PM   #22
A32Deuce's Avatar
Could be a bad breaker. They do get weak over time considering the location.
Sent from my DROID4 using Tapatalk
A32Deuce is offline   Reply With Quote
Old 04-04-2016, 05:17 PM   #23
Sure enough it was the positive circuit breaker...ugh... Took forever to get that thing off only to find out there was a reset! Oh well live and learn! Thanks for the help!
Old 04-04-2016, 08:49 PM   #24
jjgabe's Avatar
What do you mean positive circuit breaker? Please provide more info.
jjgabe is offline   Reply With Quote
Old 04-05-2016, 09:26 PM   #25
VinceU's Avatar
A positive circuit breaker is simply a over current protection device which can be a fuse, installed to protect a branch circuit lead from the positive battery terminal. The name is misleading because the negative side of the circuits nearly always lead to ground and battery negative terminal. It's not typical to add a circuit breaker or fuse in these leads.
Old 04-06-2016, 01:11 AM   #26
jjgabe's Avatar
Thank you. Where is this positive circuit breaker located?
Old 04-06-2016, 09:17 AM   #27
Right behind the propane tanks on the frame.
Old 04-06-2016, 10:11 AM   #28
jjgabe's Avatar
Awesome. Thank you.
battery, power
