Old 06-28-2016, 01:25 AM   #1
DodgeNerd85's Avatar
Propane Quick Connect
Has anyone used their quick connect propane connection?
I finally broke down and bought a MB Sturgis hose that connects directly to my weber q100 from the propane connecter under the trailer.
Super excited only to be let down, the system wouldn't pump out enough propane to give to the grill enough juice to get hot. (Even with the burner set to high, the flame was barely on)
I tried adjusting the regulator on the trailers propane tanks, it did nothing.
Was I mistaken, is this quick connect propane system not designed for small grills?
The little weber probably has a regulator built in... do I need to disable that thing too?
2015 Stealth 2812G
2012 3500 Mega Cab DRW
ISR Series SuperGlide 16K
GO NAVY
DodgeNerd85 is offline   Reply With Quote
Old 06-28-2016, 04:03 AM   #2
nomad297's Avatar
You must remove the regulator from your grill.
Bruce
nomad297 is online now   Reply With Quote
Old 06-28-2016, 05:38 AM   #3
Time-Travelers's Avatar
My Weber Q 1200 grill and converter kit just arrived yesterday so I haven't had a chance to hook it up yet, but this is what I'm going to try... I also want to get another quick connect fitting to put on the removed regulator to retain the use of the portable tanks.
https://youtu.be/fjCeW5s7wvk
Linda & Paul
2014 Rockwood Signature Ultralight 8292WS
2016 Ford F-150 XLT 4X4 Supercab,
3.5L V-6 Ecoboost
Time-Travelers is offline   Reply With Quote
Old 06-28-2016, 06:08 AM   #4
Is that grill a high or low pressure grill? If it is a high pressure and you are hooking into you propane plumbing on you camper, you may be only getting low pressure. You may need to add a high pressure regulator in front of you low pressure regulator with a tee that runs your grill.
I have an outdoor high pressure stove that requires 16 pounds of pressure. I have to use an adjustable regulator that will give that much pressure. I placed it in front of the low pressure regulator with a tee so I can connect my outdoor stove. Also, normally a quick connect is not for high pressure. Those are for low pressure.
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Asrabbit is online now   Reply With Quote
Old 06-28-2016, 06:14 AM   #5
I bought a separate hose and remove the tank and connect to my weber. Works great. A little inconvenient moving the tank tho.
Wumba is offline   Reply With Quote
Old 06-28-2016, 06:26 AM   #6
nomad297's Avatar
That's all you have to do.
Bruce
Old 06-28-2016, 07:48 PM   #7
[QUOTE=Wumba;1241715]I bought a separate hose and remove the tank and connect to my weber. Works great. A little inconvenient moving the tank
Yes, I currently have a normal 20lb tank I lug around, I don't bother removing one of the big tanks in the trailer, that's too much
2015 Stealth 2812G
GO NAVY
Old 06-28-2016, 07:50 PM   #8
Bruce
Any suggestions on removing this bad boy ?
Doesn't look adjustable either :/
2015 Stealth 2812G
GO NAVY
Old 06-28-2016, 08:57 PM   #9
dan-nickie's Avatar
Read post number 16
Weber Q Grill 2200
Dan
2014 Berkshire 390RB-60
dan-nickie is online now   Reply With Quote
Old 06-28-2016, 09:54 PM   #10
Originally Posted by dan-nickie View Post
Read post number 16
Weber Q Grill 2200
Thanks, I wish I looked for this before I bought my hose, cause my hose connection is the 1lb male side, arg
2015 Stealth 2812G
GO NAVY
propane
