Old 09-19-2016, 07:28 PM   #1
Smile Shower door
The glass shower door on our 2016 ss9913 Stealth does not stay on the lower track. Therefore, the door does not close properly. How can we fix that? Thanks in advance.
Clemons is offline   Reply With Quote
Old 09-21-2016, 01:22 PM   #2
Clemons;1321549]The glass shower door on our 2016 ss9913 Stealth does not stay on the lower track. Therefore, the door does not close properly. How can we fix that? Thanks in advance. I have added photos of the problem. As you can see only one tab in the bottom rail is in place, the other 3 are not. This doesn't allow for the door to completely close.
ID:	120885   Click image for larger version
Old 10-14-2016, 12:15 AM   #3
PolarisGuy's Avatar
Any new news on this? Warranty item?
RV: 2016 Stealth WA2916 Toy Hauler
TV: 2005 F250 PSD
2012 Polaris Sportsman 850XP
2014 Brute Force 300 (daughters)
2016 Days Camped: 22
Check Us Out On YOUTUBE!!
PolarisGuy is offline   Reply With Quote
Old 10-20-2016, 05:12 PM   #4
I have the same problem and the tabs seem to slip back into place as they go around the curve when I put a little pressure on the bottom of the door.
Just me, my girlfriend and our crazy Boxer Stella.
'13 GMC 1500 Sierra Denali, '14 Stealth SS1913, '08 YFZ450 with some crazy engine mods.
vocoder is offline   Reply With Quote
Old 10-20-2016, 05:18 PM   #5
Door hinges? My shower door started giving me fits a couple years ago. I finally traced the problem to worn hinges. On mine the hinge pinmis a piece of nylon maybe 3/16 inches in doameter by about 1/4 inch long on the small portion. On the larger part its about 1/4 diameter. There is a screw thru the larger part into the door. To supposidly hold things in place. If that is hoe yours works, then replacing the hinge pins is how to fix the problem.
donniedu is offline   Reply With Quote
door, show, shower
