Old 11-11-2013, 09:51 PM   #1
Solar panel: Winterize or leave batteries in during storage
We have a Stealth with the Go Power 160w solar panel system. I read the manual and the charger seems to be pretty high tech with lots of battery maintenance features built in.
We plan to use our trailer a few times during the winter and it would be a lot easier to leave the battery in and let the solar system maintain it. GP electronics recommends covering the panel and removing the battery during the winter.
Anyone in a cold climate just leave the batteries in and let the solar panel do its job?
BTW we have the battery disconnect switch inside at the convert and disconnect it when not in use.
hammick is offline   Reply With Quote
Old 11-12-2013, 12:55 AM   #2
Jjs2000z's Avatar
I live in Southern California so winter doesn't Affect me. Even though the battery disconnect is turned off the batteries will still get charged. The solar panel is wired directly to the batteries. I think this is the best upgrade on these trailers. It saves me a ton of money by not having to turn in my generator just to charge the batteries. Also I plug in all my electronics throughout the day and charge everything.
2014 stealth 2714
Jjs2000z is offline   Reply With Quote
Old 11-12-2013, 09:34 AM   #3
Denver, CO
garbonz's Avatar
If you solar controller is wired direct as mentioned here, then you should have no problem. You may just want to spot check the voltage a few times to make sure that you are staying fully charged
2017 Fuse 23T
Old 11-12-2013, 09:49 AM   #4
Thanks for the replies. My solar charger goes directly to the battery and does charge when the disconnect is off.
Old 11-12-2013, 12:08 PM   #5
Jjs2000z's Avatar
Yes I have checked and the voltage is correct and my batteries are always charged. I must say, solar on an RV is the best thing ever! I save a ton of money in gas not having to run my generator.
2014 stealth 2714
Old 11-12-2013, 09:30 PM   #6
jonnys_walkers's Avatar
If you live in a climate that the panels get covered with snow they will not charge.
Never enough camping!!
jonnys_walkers is offline   Reply With Quote
Old 11-12-2013, 11:26 PM   #7
chiefly1's Avatar
I have the same solar system and it works awesome at maintaining the batteries even with the ghost drains as I leave the batteries connected. I don't have to worry about snow though.
chiefly1 is offline   Reply With Quote
solar, storage, winter, winterize, battery
