Old 11-14-2015, 03:46 PM   #1
Ss18-12 water pump
Cant find access to pump under sink. Does anyone known if its behind the fuse panel ?
Ernst1303 is offline   Reply With Quote
Old 11-14-2015, 04:18 PM   #2
northstar1960's Avatar
Don't know your unit but would guess it's not behind the electric panel . i would run some water and listen to the pump and go from there
northstar1960 is offline   Reply With Quote
Old 11-14-2015, 04:34 PM   #3
Sounds like its under the sink. But cant remove the panel between the electric panel and sink.
Old 11-14-2015, 06:46 PM   #4
there should be a removable panel close by, mine sits just under the sink with no panels
you should not have to mess with any electric panel .pictures maybe
pump, water, water pump
