Old 05-26-2015, 03:09 PM   #1
SS1913 and satellite
i've seen some advertisements that the 2015 stealth is wired for Cable, Satellite, and OTA.
does anyone know if i can hook a tailgator satellite dish to the stock stealth coax input?
jessepdx is offline   Reply With Quote
Old 05-28-2015, 04:59 PM   #2
I haven't done it - but when showing my 2014 1913 to an RV-savvy buddy of mine, he commented on the ease of hooking a DirecTV receiver up - dish connects to the outside, receiver between ceiling jack on the wall, and the TV Antenna on the roof powered off.
Should be good to go! Let us know how it works if you try.
Just me, my girlfriend and our crazy Boxer Stella.
'13 GMC 1500 Sierra Denali, '14 Stealth SS1913, '08 YFZ450 with some crazy engine mods.
vocoder is offline   Reply With Quote
Old 05-28-2015, 06:42 PM   #3
bubbles's Avatar
I am assuming you are referring to the park cable input. Should be able to and the other end to the sat receiver where ever that is inside your unit.
Old 05-28-2015, 07:14 PM   #4
Stormrider151's Avatar
If it's satellite prepped it should have two connections on the outside. One for cable and one for satellite. Inside the trailer close to the TV there should be a wall plate with the same connections. Satellite will not go through the TV booster on or off. The receiver needs a straight feed from the dish to work. Otherwise the picture will be extremely snowy. My trailer was supposed to be prepped and wasn't. I had to do a little rewiring to get it to work.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 06-03-2015, 02:40 PM   #5
Jjs2000z's Avatar
Yes you should be able to hook up the cable to the Rv from your satellite dish.
2014 stealth 2714
Jjs2000z is offline   Reply With Quote
Old 07-21-2015, 05:57 PM   #6
it turn out my question is moot, i bought a tailgator, but it doesn't work anywhere i camp. I boondock and ride dirtbikes in oregon. far too many trees it seems...
i took the tailgator back. the roof power OTA antenna works great most places though
Old 07-22-2015, 05:44 PM   #7
I have a winegard carry out. (Version 1) it has never failed to receive a signal even in very wooded areas. You might try that. Easy to use and set up.
Old 07-22-2015, 05:50 PM   #8
nomad297's Avatar
I can always get a shot at all three of the satellites I need through the trees. I have over 150 feet of cable and have used that much to connect my DirecTv Slimline dish to the three receivers in my travel trailer. However, I rarely need more than 50 feet.
Bruce
Old 07-22-2015, 07:34 PM   #9
Left Coast
My King Flex also works just fine .....100' cable or 50'
satellite
