Old 09-02-2015, 05:54 PM   #1
Stealth 2515 black water tank flush.
Be advised. 2016 SA2515 had the black water tank rinse fitting mounted too close to the generator. During the generator break in routine, hot air from the genset melted the fitting, causing it to fail and leak at first use. Dealer had to patch original tank broach and install a new valve and a heat shield to keep this from happening again, and to deflect the hot air in future. Enclosed underbody option, so the panel had to be cut for access and reworked. I'm not terribly excited about this one. Brand new trailer and now I have an extra hole in my black water tank, as well as an access hatch cut into my underbody enclosure. I'm confident the dealer will do a good job. But....
prestonj12 is offline   Reply With Quote
black, black water, tank, water, water tank
