Old 08-11-2013, 07:15 PM   #1
Stealth SS2216 Shower Drain Question... Please Help!
I'm really embarassed to ask this question:
How do you work the drain plug on the shower of the 2013 Stealth SS2216 toy hauler? We just took ours out for the first time, and I took a shower. I can't get the drain plug to lift so that the water can drain adequately... It eventually drained out, but I just don't think that's the way it is supposed to work.
I hope someone can help me. It should be such a simple thing, but I can't find anything about it anywhere!!!
Lisa
Lisa Grant is offline   Reply With Quote
Old 07-19-2014, 09:49 PM   #2
When you pick it up, rotate it a bit and it should lock up in the open position.
MBart is offline   Reply With Quote
Old 08-10-2014, 11:24 PM   #3
same problem in 2116!
We simply cannot get the shower plug to raise at all. Did you ever solve this problem??
ShootersWife is offline   Reply With Quote
Old 08-11-2014, 12:30 PM   #4
Ok, proper application of force worked (pliers and a towel plus some muscle pulling straight up).
drain, show, shower
