Old 07-27-2013, 08:54 AM   #1
soccerloco's Avatar
Switching from 12 volt to 6 volt batteries
Trying to switch from 12 to 6 volt batteries on my rv. Here are my question. My unit had two 12 volt batteries wired In parallel. There is cabling on both sides of the compartment. One side has standard black red cables. Other side had white and black cables. I am confused about how I can wire the new 6 volts with this cabling. Help
soccerloco is offline   Reply With Quote
Old 07-27-2013, 08:57 AM   #2
fonzie's Avatar
Best to take pictures and post so people can help.....
Fonzie
Old 07-27-2013, 09:19 AM   #3
soccerloco's Avatar
Will do thanks
Old 07-29-2013, 08:51 AM   #4
soccerloco's Avatar
Thanks to everyone. Got it figured out. Very happy to have the better 6 volt batteries. It was different having two sets of cabling. Joined red cables to positive one battery then joined black and white cables on negative on other battery. Then ran cable to join the negative and positive on open terminals. 12 volts.
Old 07-29-2013, 09:20 AM   #5
Herk7769's Avatar
Just to be sure:
HAM CALLSIGN - KC3FFW
Old 07-29-2013, 09:29 AM   #6
soccerloco's Avatar
That's it other than where the negative and positive leads go to the trailer there are two. It works perfectly. Thanks
