Old 08-14-2016, 09:20 PM   #1
AMG
Upgrade A/C registers to adjustable louvers
If anyone else has the non-adjustable (2016 and below, cant speak for 2017) louvers for their A/C returns in their ceiling, you may desire the ability to control flow. Here is a very easy fix that takes 60 seconds to swap all of them in your TH. Simply pull the current fixed louver unit out, leaving the ring that is screwed in (3 screws under neath) and then snap in the adjustable one. Identical under mount piece, same mfgr, simply the main unit swap.
What my unit came with:
D&W JetStream #8950
Venting Products / AC Vents / "Jet Stream" #8950 Wide Open Louvered RV AC Vent - DW Inc.
What you replace it with
D&W JetStream #8850
Venting Products / AC Vents / "Jet Stream" #8850 Fully Adjustable Large RV AC Ceiling Vent - DW Inc.
Here's some pics
ID:	117298   Click image for larger version
ID:	117299   Click image for larger version
ID:	117300   Click image for larger version
TH : 2016 Stealth WA2916
TV : 2012 Ford F-250 PSD
AMG is offline   Reply With Quote
Old 08-14-2016, 09:39 PM   #2
Hedrock's Avatar
I did the same swap in my 30HDS and the difference is very noticeable
2016 Hyper Lite XLR 30HDS
Hedrock is offline   Reply With Quote
Old 08-15-2016, 09:39 AM   #3
Head Rambler
Just swapped several in the 29RKSS and love the way they work.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-30-2016, 02:32 AM   #4
Thanks for posting. After reading this, I followed link you gave and ordered four for our Shockwave F28SAGDX fifth wheel. It took less than 30 seconds per vent to pop in the adjustable vents. Great upgrade 😊. Should have come that way, imho.
Jim
mcwhirtj is offline   Reply With Quote
Old 08-30-2016, 05:50 AM   #5
Did that mod last week. Work great.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2016: 38 nights camped
Teamfour is offline   Reply With Quote
upgrade
