Old 01-12-2015, 08:24 PM   #1
Vent Lid Replacement for Forest River Stealth trailer
Here's a quick how-to for replacing the vent lids on your Stealth. These instructions and parts may work on other Forest River or other brand trailer vents as well, but this is the process I went through for my Forest River Stealth FS2410 vent lid replacement.
You will need to remove parts inside the trailer AND on the roof, so bring a ladder for outside, step-stool/crate to reach the ceiling inside, phillips screwdriver, needle-nose pliers and something to clean the existing rubber seals.
First watch this great video from etrailer.com showing the install process:
http://images.etrailer.com/Merchant2...554-03_web.mp4
Next determine the correct replacement lid - you need to know the vent size and hinge type, so measure your vent dimensions (not the lid) and look at the hinges. I forgot to measure my vent dimensions, but learned from several sources that most square roof vents are a standard size. The replacement lids I found with the correct hinge only came in one size.
Determining The Correct Replacement Vent Cover For Trailer Roof Vent | etrailer.com
Forest River says they use Elixir vents which match this hinge type: Ventline/Elixir (see image below).
Here is a picture of my lid with the hinge along the back.
Name:	hinge on back.JPG
Next, purchase your replacement lids. My existing lid had the words “Heng’s Industries” on the side so I Googled “heng's industries vent lid” and found this part on rvsupplyparts.com:
https://www.rvsupplyparts.com/catalo...-lid-8693.html
These others appeared to match the type and size as well:
Camping World:
Replacement Vent Lid - Ventline pre-2008 & Elixir 1994 and up, White - Camco 40155 - Vents - Camping World
and
Etrailer.com:
Vent Cover for Ventline Old Style Rounded Dome Trailer Roof Vents - White Ventline RV and Camping BV0554-01
Once you get your lids, you should be able to follow the instructions in the above etrailer.com video and be done. The new lids should slide right on - the hinge match-up looks like this:
Name:	fitting new lid.JPG
And the end result!
And while I was up there, I sprayed them all with Armor All, cuz I roll like dat.
Good luck - post any questions and I'll try to help.
ryandee is offline   Reply With Quote
forest river, hinge, replacement, trailer, vent
