Old 11-03-2013, 06:13 PM   #1
jjgabe's Avatar
Water level
Have a Stealth WA2715. It has the optional 60 gallon potable water tank in addition to the standard 106 gallons. I am wondering if this is a different tank all together or if the standard tank is larger. I put in a lot of water after reaching full on the level indicator. There are times that I don't want to take out all 160 gallons. But I don't yet know how to interpret the indicator. Last time I only filled partial we ran out of water.
jjgabe is offline   Reply With Quote
Old 11-04-2013, 08:21 PM   #2
Jjs2000z's Avatar
There is a separate tank. Look under the trailer and you will see these two linked together. I always fill no matter what. You can always dump the water when you leave so you don't have to haul it to the dumping station.
2014 stealth 2714
Jjs2000z is offline   Reply With Quote
Old 11-11-2013, 09:38 PM   #3
I have the 2313 and I think that the water goes into the main tank and then flows into the extra 60 gal tank. I'll take a closer look at mine next time it is warm out and on the driveway. Not sure if the 60 gal tank has the 1/3 sensor on it or if all sensors are on the main tank.
hammick is offline   Reply With Quote
Old 03-16-2014, 11:31 AM   #4
Jjs2000z's Avatar
Did you find out about the sensor?
2014 stealth 2714
Old 03-16-2014, 02:58 PM   #5
Not yet but it shouldn't be too long before I have it out of storage and ready for the season.
Old 03-16-2014, 03:15 PM   #6
Witch Doctor's Avatar
Man that is a lot of water. never new they made something that big......
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 03-16-2014, 10:09 PM   #7
Jjs2000z's Avatar
There are two major things you must have when boon dock camping, lots of water, and lots of power ( solar )
2014 stealth 2714
Old 07-28-2014, 10:37 PM   #8
TheUO's Avatar
I would have to really get down there and look, but from the peeks I've had under the 2715 it looks like the supplemental 60 gallon tank is higher than the 100 and feeds via a gravity tube. I would imagine you're filling first through the 60 and the sensors are only in the 100 which fills first.
If I'm wrong, I'm likely incorrect on which tank is first in the line.
I'll get under there sometime soon and verify which tank is which.
TheUO is offline   Reply With Quote
Old 08-09-2014, 11:04 AM   #9
John McClain's Avatar
You can put a shut off valve between the two tanks
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
John McClain is offline   Reply With Quote
Old 08-09-2014, 11:57 AM   #10
vinmaker's Avatar
Sounds like good advice.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
