Old 08-12-2018, 08:15 PM   #1
Broken Spring Hanger
2015 Nitro XLR broken bolt on the right rear spring and lost the adjustment cams and damaged the spring hanger. Where can I purchase a new hanger and adjustment cams?
nitro jim is offline   Reply With Quote
Old 08-13-2018, 12:29 PM   #2
Head Rambler
Have you looked at etrailer.com?
Gotta go campin!
Old 08-13-2018, 12:55 PM   #3
On spring hangers, nothing special.
Just a piece of ordinary mild sheet steel (1/8" or 3/16"?). Available at any shop that sells misc. metals. Sometimes these shops have a shelf or bin of scrap pieces that can be had for cheap. Could cut with a hacksaw or cutoff wheel in an angle grinder (or a few other methods) to match the existing dimension. The steel shop should also be able to cut a square piece for you on a chop saw or band saw. Use a file to smooth off the cuts and drill holes to suit. Course, some welding required to frame.
Spring hangers are sold separately like at easternmarine.com here for example.
https://www.easternmarine.com/Leaf-S...Hangers-Seats/
If you want simplest/fastest, go to a frame and axle shop.
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
myredracer is offline   Reply With Quote
