Old 08-25-2015, 03:30 PM   #1
strut526's Avatar
I am getting to old for this..reaching the drain valves
I have 3 tanks to dump on my camper, i have to basically get on the ground to pull the handles. Do they make extensions for these? or anyone done a modifacation to make it easier? i am seasonal now, so traveling is no longer an issue.
2005 American Sport -Went seasonal 2012 Irish Hills, Michigan
strut526 is offline   Reply With Quote
Old 08-25-2015, 03:48 PM   #2
fonzie's Avatar
Don't know if they make extension but you could always install electric valves.....
Automatic Drain Valve - Barker 24130 - Sewer Valves - Camping World
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 08-25-2015, 03:53 PM   #3
strut526's Avatar
Thanks, but with 3 valves, that would be expensive! I will check them out though...
Old 08-25-2015, 03:55 PM   #4
TURBS's Avatar
Camco makes a cheaper version I believe
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-25-2015, 04:01 PM   #5
rsdata's Avatar
I don't know if this would work, but maybe cut the gate valves off with some pipe still attached, add a PVC coupler pipe, then bring the pipe out further and re-cement the cutoff gate valve back on? the pipes may or may not be standard PVC pip size...
Too much of anything is bad, but too much good whiskey is barely enough. Mark Twain
2014 Shamrock 183
rsdata is online now   Reply With Quote
Old 08-25-2015, 04:22 PM   #6
cowboy72's Avatar
I believe you could easily add an extension onto it. I had to as I broke mine off about 2" out. I just went an bought some quarter inch threaded bar from Canadian Tire and a quarter inch coupler. When I go back to the Trailer I'll take a picture so you will have a better understanding.
cowboy72 is offline   Reply With Quote
Old 08-25-2015, 04:46 PM   #7
Taranwanderer's Avatar
Worth every penny. Read through this thread, it describes my drain valve odyssey:
Replacment sewer drain valves
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (18)21 (19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 08-26-2015, 03:54 PM   #8
I installed a treaded eye hook on the end of and old broom stick. I can hook the drain valve and pull it open and close it without getting down on my knees. I was simple to make and easy to use. This should solve your problem.
erxq is offline   Reply With Quote
Old 08-26-2015, 06:08 PM   #9
Cornelius's Avatar
It is easy to extend the valve handles. Several years ago, I owned a Roadtrek with inconveniently located valves and added extensions. The valve handles are threaded and unscrew from the valve. Use a threaded coupler to add a length of threaded rod cut to the desired additional length. Then screw the handle back on to the extended rod. You may also want to use some thread lock, such as Loc-tite to secure everything together. You can buy the rod and coupler at a hardware store.
2010 Georgetown 373
2013 Jeep Wrangler
Cornelius is offline   Reply With Quote
Old 08-26-2015, 08:56 PM   #10
Itsthetwoofus's Avatar
Smile
Using a threaded rod and little pvc pipe about 2 or 3 feet (as long as you need) ..un screw the handle from the dump hadle, screw the threaded rod in where the handle was and slide the long pvc pipe over it and then screw the other end of the rod into the handle. Using what ever you want fill both ends with that stuff that hardens on both ends to make it a secure extension. Works great and using a bungee strap to hold it up to secure it when slides are open.
I can take a picture for you but will have to wait till tomorrow.
2011 Cedar Creek 36B2 ordered with outside kitchen removed and a nice big wardrobe in it's place.
Pulled with a 2011 F-250 Super Duty 6.7 Diesel Crew Cab and 8' box with a Hensley BD-3 Trailer Saver. F R O G members.
<a href=http://www.forestriverforums.com/attachments/signaturepics/sigpic9630_4.gif target=_blank>http://www.forestriverforums.com/att...gpic9630_4.gif</a>
Itsthetwoofus is offline   Reply With Quote
Old 09-10-2015, 12:51 PM   #11
For the record......the Fresh Water Tank Drain has a large "sill key"-tyope pastic ball valve open/shut counter clockwise open, clockwise shut, but the dang thing is all the way under the middle of the bottom of the 2016 261BHXL, right at the low center of the Fresh Water Tank. I made this 4&1/2 foot pvc tool and now it can be accessed from the side of the camper, gently and effectively. (one 4 ft length of pvc pipe, a "T" connection on both ends, then used ny Dremel to cut a trough for the cock valve, and use the other "T" end to gently turn for operation. I wish it were easier to post photos, here.
CWElliott is offline   Reply With Quote
drain, valve
