Old 03-27-2011, 11:28 AM   #1
Where is the full coach 100% water filter?
We just purchased a used 2006 All American 385RLTS. According to the brochure for that year, there was a full coach 100% water filter as a standard option. Does anyone know if this is true, and where I could find it if so? Also, there is a second water inlet above the one that is marked for city water. I've read this is for the black tank flush. Can anyone confirm this?
Brad and Lynn T is offline   Reply With Quote
Old 03-27-2011, 11:42 AM   #2
kalik282's Avatar
I'm not sure where the filter is on your particular trailer, but, FR usually puts them very close to the water pump. If you can find your pump, the filter is usually there too. You can find the pump by following the noise. Often, you will find them behind a cabinet door with hinges on both sides. Just take the screws out of one side and open the door. If not behind a cabinet door, then look behind any false panels inside cabinets or outside storage compartments.
Good luck!
John
John & Nicole
2004 Ford Excursion 6.0L 4x4
2011 Flagstaff 831FKBSS
Nights Camped: '06=122 '07=12 '08=18 '09=10 '10=18 '11=28 '12=16
kalik282 is offline   Reply With Quote
Old 03-27-2011, 03:17 PM   #3
There is always the possibility that the previous owner have remove the water filter and connected the line direct?
capucine is offline   Reply With Quote
Old 03-27-2011, 04:36 PM   #4
jimh's Avatar
can u locate the fresh water holding tank inlet? on my travel trailer, the one next to the city inlet is to fill the fresh water tank. (the fresh fill and city connections are less than 6" apart; the back water flush is several feet away don't know abt a motor home).
jimh is offline   Reply With Quote
Old 03-28-2011, 05:13 AM   #5
cardinal4fun's Avatar
If your unit does have a filter, as said before it should be close to the water pump. The pump may be in out side storage area back wall. It will either be for the flush or it could be to fill your fresh water holding tank. I know on mine I have one for direct water and the other to fill the holding tank. I would not think a black water flush would be that close to fresh water. If you thinks its black tank hook water up to it and open up toilet flush you will hear the water coming in.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
Old 04-17-2011, 02:41 PM   #6
Bear's Avatar
It has a filter from factory. Crawl into your storage compartment, you will see a squar pice of rug covered wood hung on the rear wall with 4 wood screws, remove it and you will find the water filter and water pump. And yes, that is a black water flush. DO NOT have water running in there unless the black tank valve is open
2000 Volvo 660 D12 425 hp 1550 torque 15 speed, Trailer Saver air ride hitch. 2006 Canadian Sport 385 RLTS 40'10" triple slide, triple axle 5'er toybox, 300 watts solar, 3000 watt inverter, Onan 5500 Marques Platnum. 1998 Polaris 300 Explorer 4X4 quad, 2003 Polaris 700 Sportsman 4X4 quad, 1994 Jeep YJ "TOAD" 3" lift 31" ProComp Mud Terrain tires
http://community.webshots.com/user/Bears319
http://www.picturetrail.com/bears319
Mission Statement : ZZZZzzzzz
Bear is offline   Reply With Quote
