Old 07-03-2013, 12:47 AM   #1
290RLT Stabilization Problems
Hi everyone....We are currently in the middle of a camping trip with our 2013 Crusader 290RLT and having problems with the unit rocking and bouncing when walking around. Walking in any part of the RV causes it to bounce and shake.
I have tried a number of things to solve the problem but so far nothing has solved the problem.
The rear stabilizer jacks are down; I have bal x-chocks between both sets of tires; I have regular tire chocks on the ground at each of the 4 tires; I have a tripod installed under the king pin.
I have considered jacks under the slide outs but have been told that probably won't help.
Has anyone who has the 290RLT been able to solve this problem?
Crusaderguy is offline   Reply With Quote
Old 07-03-2013, 07:08 AM   #2
Ddubya's Avatar
I installed the Steady Fast bars on mine and have been living in the 290 for three months while building a house. I haveno issues with bouncing
Ddubya is offline   Reply With Quote
Old 07-03-2013, 07:51 AM   #3
Installing JT Strongarms front & rear works great for us,
link: JTRV.COM
Old 07-03-2013, 10:07 AM   #4
Fulltime family RVer
As indicated above - some kind of triangulation stabilization helps. Not enough for us- I'm looking at some scissor jacks to put near the axles.
Learn To RV: Shake, shake, shake - RV Stabilization
ependydad is online now   Reply With Quote
Old 08-10-2013, 05:09 PM   #5
Claude002's Avatar
Have the same RV 290RLT 2013 and no tripod used 1 month and have no bouncing or other issues of this nature
Claude002
Claude002 is offline   Reply With Quote
Old 08-22-2013, 10:57 PM   #6
Ddubya - did you have any trouble with the battery compartment being in the way when you mounted your Steady Fast bars?
Dennis & April Holder
2012 Prime Time Crusader 290RLT
DHolder is offline   Reply With Quote
Old 08-23-2013, 06:54 PM   #7
DHolder,
I had a similar problem and made a frame out of 2x4s on edge screwed together with deck screws that would fit tight around the batt box. I removed the battery box, set the frame inside and screwed it into place. Then set bottom of battery box into this wood frame and secured. Worked like a charm.
2014 Crusader 330MKS Touring Edition
2006 Chevy 2500HD, Duramax/Allison
Firestone Ride-Rite air springs
SuperGlide hitch
Tbonnett65 is offline   Reply With Quote
Old 08-24-2013, 06:20 AM   #8
Ddubya's Avatar
DHolder
I will look at mine. I remember having that concern but don't remember what I did.
2017 Alpine 3401RS,Titan Disc,Morryde SRE 4000, 2016 Ram 3500HD Laramie SRW,LWB,4X4, Aisin transmission
Old 08-24-2013, 04:37 PM   #9
Ddubya's Avatar
DHolder
I looked at mine and all I had to do was attach the stabilizer bar toward the front of the landing pad and it cleared the battery tray.
Old 08-26-2013, 12:48 AM   #10
Plug It Right
The aftermarket permanently attached stabilizer systems work great. We tried the Tri Pod route, even adding extra rear arm jacks. While they helped some, nothing worked until we put on our stabilizers. 7 years later, I would never be without them, Hugs, Di
2014 Ram Dually Pickup, Tailgate Easylift, Do More Slide Step & AMP side steps
1996/2010 Triple Slide Carriage, Mor/Ryde Suspension, Kodiak Disc Brakes, Big Foot Automatic Leveling System, TST Tire Pressure Monitoring System, Plug It Right Stabilizers.http://www.plugitright.com/5thwheelREDO.html
Dutch & Di is offline   Reply With Quote
