Old 05-02-2012, 04:40 AM   #11
I'll see what I can do. It may be a little while as the weather here is not cooperating at the moment. I'm hoping to have this complete by the end of this weekend.
mblanks2 is offline   Reply With Quote
Old 05-06-2012, 06:27 AM   #12
Alright, finally completed the a/c project. Here are somes pics. This is a Coleman Mach 3 13,500 btuh a/c. The smaller breaker panel has it's own power supply cord sized for 20 amps and weather tite ends. The unit is controlled by the existing thermostat. I have it wired to operate at the same time as the original 15,000 btuh a/c. If I do not have a connection for the 20 amp service, the unit simply does not function. I added this because the rear of our 2012 Rockwood 8312SS was hotter than the other areas. I added two ceiling vents in the kitchen area and we can close off the ones in the rear when I'm able to operate the second a/c. When I can't, then we will switch use of the vents.
ID:	13295   Click image for larger version
ID:	13296   Click image for larger version
ID:	13297   Click image for larger version
ID:	13298   Click image for larger version
Old 05-06-2012, 06:28 AM   #13
A few more pics.
ID:	13300   Click image for larger version
ID:	13301   Click image for larger version
ID:	13302   Click image for larger version
ID:	13303   Click image for larger version
Old 05-06-2012, 06:29 AM   #14
Last few pics.
ID:	13305   Click image for larger version
ID:	13306   Click image for larger version
ID:	13307   Click image for larger version
ID:	13308   Click image for larger version
Old 05-06-2012, 06:38 AM   #15
Oakman's Avatar
Great job! Very professional looking installation.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 05-06-2012, 08:22 AM   #16
J_KHawthorne's Avatar
beautiful job!
Jim & Kathy
2012 Crusader 290RLT TE, TrailAir flex pin: 2012 Toyota Tundra 5.7 SR5 Dbl cab 4X2 Tow, 4.30 gears, RideRite air, TRD cold-air induction & dual exhaust: Reese 16K Slider: TST tpms
Miles towed to date: 18,950 Nights camped 192
J_KHawthorne is offline   Reply With Quote
Old 05-06-2012, 11:55 AM   #17
Thanks, It works very well. It was cool here yesterday once I completed the job, but the pair of ac's dropped the temperature inside from 76 - 71 and the humidity from 59 to 43 in about ten minutes. I spoke with my dealer and they had stated that I didn't need to provide additional support or bracing, but I decided to anyway. Rather be safe than sorry.
Old 05-06-2012, 06:14 PM   #18
pwrboatfan's Avatar
Great job...that is a very clean install! What did you do to add support?
2006 Salem 392FKTB PT
Seasonal Camping at Pomme De Terre Lake in MO
pwrboatfan is offline   Reply With Quote
Old 05-06-2012, 07:00 PM   #19
Notice in the third picture. I cut out styrofoam and added a 4" wide x 3/4" thick board on front and back so that when the system was sandwiched together it wouldn't collapse the roof.
Old 05-07-2012, 12:01 PM   #20
pwrboatfan's Avatar
I see what you are saying. Great install, I think I am going to tackle this one. I helped my neighbor this weekend replace his 13,500BTU Mach 3 with a 15,000 BTU Mach 15. I could not believe how easy it was to replace. I think I will have more time removing the skylight then installing mine once we get the wiring in place.
290rlt
