Old 01-15-2012, 11:40 AM   #1
2nd AC in 320 Crusader
We are thinking about adding a second A/C in our crusader When we put the vent cover on we noticed there doesn't seem like a lot of room between the vent and the antenna. We also noticed that we don't have the blank receptacle cover in the ceiling in the bedroom that most other 5th wheel's have that are equipped for a second A/C. We do have the breaker just not sure about everything else.
Has anyone set up the 2nd A/C or thought about it??
Brian, Kellie, Breanna & Alyssa
2011 Crusader 320RLT
BC11 is offline   Reply With Quote
Old 01-15-2012, 03:38 PM   #2
M109Rrider's Avatar
Curious as well.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 01-15-2012, 03:45 PM   #3
I have the second A/C in my 2012 Crusader 320RLT. Had it put in at the dealer when we bought it. You should have no problem and I would assume the wiring is in the hole of the vent.
southernsky is offline   Reply With Quote
Old 01-15-2012, 04:17 PM   #4
M109Rrider's Avatar
Is there a 2nd thermostat?
Jason and Billie
Old 01-15-2012, 05:00 PM   #5
No second thermostat and no duct work. It's like the old time roof A/C everything works from the unit.
Old 01-15-2012, 06:19 PM   #6
M109Rrider's Avatar
Excellent info. Thanks!
Jason and Billie
Old 01-15-2012, 06:55 PM   #7
southernsky - Thank you! We thought the wiring was through the vent. I think our problem is going to be that we have a wingman on the antenna which is taking up more room. So I guess if we get a 2nd A/C we won't be using the wingman.
Old 01-15-2012, 07:46 PM   #8
My trailer has the
Winguard batwing , I dunno if that's the same as the wingman.
No problem with the second A/C.
Old 01-16-2012, 01:44 PM   #9
Commercial Member
FYI - all of the feedback in this thread is right on - good job, folks!
PTM
RV Guy is offline   Reply With Quote
Old 01-20-2012, 02:16 PM   #10
RossandDonna's Avatar
Do you have to upgrade to fifty amp service?
2012 Crusader 290RLT
2013 F350 Lariat Crew Cab DRW 6.7L Diesel
RossandDonna is offline   Reply With Quote
