Old 05-27-2014, 12:14 PM   #11
Lynkage's Avatar
I can't seem to find the thread but someone had a very detailed thread about sealing up the duct work and the current single AC worked much better.
I think I would start there as I will as soon as I find the thread!!
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 05-27-2014, 12:15 PM   #12
B and B's Avatar
Originally Posted by volwing1 View Post
Does the 2012 Crusader 290RLT with 30 amp service also accommodate a 2nd AC?
I have been thinking of the same thing for my Rockwood which is 30 amp. There are always 20 amp outlets at most park pedestals. Run the second AC to a separate power disconnect and hook up just this AC to the 20 service using the 30 amp for the rest of the trailer. There are 50 amp cheater dog bones that split the second 120 VAC leg to a standard plug, this is more or less the same thing.Now the question that would be raised is 2 service entrance for the same trailer. I have seen this many times in TV Mobile systems, more than one source of power.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 05-27-2014, 12:25 PM   #13
I believe I remember the thread also but me and the FR search don't get along too well.
2015 Crusader 315rst
2016 Ford F350 SRW 4x4 King Ranch 6.7L
Houstonkid is offline   Reply With Quote
Old 05-27-2014, 01:10 PM   #14
pjones1969's Avatar
Not in a Crusader...... but I installed a 2nd ac in our Sabre's bedroom this weekend, it was factory prepped for 2nd ac with a separate thermostat. I was going to get a dealer to do it but got frustrated with them quoting me non-ducted units when I told them every time that I wanted ducted and already had the ductwork there so I decided to do it myself.
Its an easy project, you'll need some help to get it onto the roof and set in place. I backed my truck up to the front cap and had two guys in the bed push it up while I was on the roof with a rope, we taped cardboard to the bottom so it didn't scratch it up, went real smooth, hardest part was removing the existing vent.
I'm assuming you are taking out an existing roof vent and putting it there, do a little bit of investigating and find the wiring first and make sure you have ductwork taps already, if it is indeed prepped for a 2nd ac everything should be there. I had to remove a ceiling mounted speaker and fish around for the thermostat wiring, once you do that get the model number of your current ac and call the manufacturer and they will tell you what you need then you can download an installation manual online, and plan it out.
btw, mine was a Dometic, they were very helpful
2011 Puma Unleashed 27SBU - SOLD
2013 Sabre 32bhok-6 - SOLD
2012 Ford F250 6.2 - SOLD
2017 Heartland Cyclone 3800
2016 Ford F350 6.7 DRW
B&W Companion
pjones1969 is offline   Reply With Quote
Old 05-28-2014, 10:44 PM   #15
Please explain more. You taped into the same duct work that was existing? You had two units blowing into one ductwork? What about return air?
Robert
rscconrad is offline   Reply With Quote
Old 05-29-2014, 07:25 AM   #16
pjones1969's Avatar
I can't find this thread either right now but basically you remove your ac vent covers and tape up all of the "holes" in the transitions from the ductwork to the vent with foil tape and remove your existing air distribution box cover and make sure it is taped good in there, every hole is a path for air to escape the ductwork and enter into your roof cavity
B&W Companion
Old 05-29-2014, 07:31 AM   #17
pjones1969's Avatar
Robert
Yes, the ductwork was one common run, it already had taps where the existing vent in the bedroom was, after I removed the vent I foil taped the entire hole to tie it all together. The return air is on the air distribution box that mounts to the ceiling inside your bedroom.
Here's a pretty good illustration
R.V. Air Conditioner Troubleshooting
Here are some pictures
Name:	factory ductwork.jpg
ID:	53637   Click image for larger version
Name:	taped ductwork.jpg
ID:	53638   Click image for larger version
Name:	air distribution box.jpg
ID:	53639   Click image for larger version
Name:	ac on roof.jpg
B&W Companion
Old 05-29-2014, 07:31 AM   #18
TURBS's Avatar
Robert
Return air is done right at the AC unit.
There is no return air "duct" on a dometic.
TURBS
"Sabre owners united"
Old 05-29-2014, 07:35 AM   #19
Lynkage's Avatar
Nice pics Pjones!!
I did find at least one of the threads about it and combined with yours this should be a great thread!!
Second air conditioner
Shane & Antoinette
Old 05-29-2014, 07:39 AM   #20
pjones1969's Avatar
Nice pics Pjones!!
That's it!! subscribed for future reference
I still need to do the vents in the bunkhouse and pull the distribution box from the factory install, will do that on the next outing
B&W Companion
air conditioner, crusader
