01-31-2018, 05:06 PM
#21
Originally Posted by Casey r
Scott
What did you do about a thermostat. I have not looked at the duct work but I did pull out the vent and I have 110 volts there no other wiring. I assumed since I did not see thermostat wiring it was not ducted. I did see thin pylwood on the side that would be closest to the ducting but did not remove it. Wanting to add second a/c.
Depends on what unit you buy. Some are for use with thermostat (either single zone or multi zone), and some are controlled from the units control panel. Which one you pick depends on how easy it is to either run thermostat wires down a wall, or connect to your main thermostat and replace it with a multi zone. Most folks just use the units control panel and forego the thermostat
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
01-31-2018, 05:52 PM
#22
Unit doesn’t use a wall thermostat. It is controlled on the air diverter.
01-31-2018, 06:18 PM
#23
Usually those skylights or precut holes are 14 1/4 inch square, could you rotate the AC unit on the roof 90 degrees in either direction. The width of the shroud is not as great as the length, this may give you the clearance that you require. I ran into the same problem with our Crusader Lite. However in my case I just cut a inch off of the shroud with a band saw, it now fits snug and everything works fine.
01-31-2018, 06:20 PM
#24
Great idea. Thanks
01-31-2018, 06:57 PM
#25
Originally Posted by NMWildcat
Return air routed through 14" x 14" hole a/c and ceiling attachment (air distributor) is mounted to.
I was answering AquaMan's comment about what would be required to make the second add on A/C a true ducted system.
True, the easiest way is to get the "bottom dump" type A/C unit & just hook to the existing pre-wire. But, part of the OP's original post was noise level of the bottom dump opposed to the ducted system and his quest for possible quieter options.
2014 Prime Time Sanibel 3250
01-31-2018, 06:59 PM
#26
Gotcha.
01-31-2018, 07:05 PM
#27
Casey & Carolyn
I'm a little confused. I currently have a Dometic 15k brisk air II. Thought I would add a matching 13k unit in the bedroom. Here is where I'm confused. I thought all ducted units where remote thermostaticly controlled. Are you saying they make a ducted unit that has the controls on the unit. I have researched a little and have not come across that. If that's the case I need to look a Little deeper. It would make a very install if that's the case.
Casey and Carolyn Rice
Las Vegas Nv
2017 Prime Time Crusader Lite 29 RS
2018 Ram 3500 4x4 CC Cummins Powered
02-01-2018, 07:41 PM
#28
Originally Posted by jcairns57
Coleman Mach 3 with series 9000 ceiling air diverter/controller. Small enough to fit between wall & roof cutout.
X2 - Coleman Mach low profile unit. It'll run you right out of the bedroom with cold air. At night you can normally turn it off as the 15k ducted unit will keep up then. It's actually better having it not ducted in my opinion. You can direct the air right down on you to cool off when you need it.
_________________________
Crusader 337QBH
2019 F350 6.7L DRW CC LB 4x4 Lariat
B&W Companion 20K for OEM pucks.
02-08-2018, 10:14 AM
#29
I have the same unit and after looking at the opening for the second AC unit, I decided to go with a Fantastic vent fan with outside cover instead.
We are in Florida in the Winter months, that being said, it still gets up into the high 80's.
We leave the main AC unit on and in the evening an hour before going to bed I open up the Fantastic vent, turn it on high and pull the cooler air up into the bedroom. Then turn it on low for the remainder of the night.
Works perfectly and I don't have the additional weight of the second AC unit. Plus the constant hum of the Fantastic fan on low is much easier to sleep with than the compressor of an AC unit kicking on and off.
Fred n Wilma
2017 Ford F-150 EcoBoost
2015 Crusader 295RST
02-08-2018, 11:31 AM
#30
Citrus County, Fl.
Have you looked at the Atwood Air Command non ducted? The grill dimensions are: 21.8" L x 21" W x 2.6" H and the unit comes with a remote control. You can buy a complete 15K unit with heat pump for $737 with shipping.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
