Old 01-30-2018, 03:58 PM   #1
2nd air conditioner on 297RST
I ordered a Dometic a/c unit to install over the bedroom on my 2015 297RST but could not install it because the distance from the wall separating the bathroom & bedroom was too close. The air distribution/control box won't fit on the ceiling because it is too large. There is only 5.75 inches from the cutout to the wall. Anyone have ideas of which a/c manufacturer makes a smaller unit that will fit?
jcairns57 is offline   Reply With Quote
Old 01-31-2018, 07:32 AM   #2
SeaDog's Avatar
Why not center the new AC over the bed? It would require you cutting to fit
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 01-31-2018, 09:10 AM   #3
The hole is already factory cut & has an existing vent & is prewired for a/c.
Old 01-31-2018, 09:17 AM   #4
SeaDog's Avatar
You best bet may be to contact the factory and ask what unit they install in that position, unless it was designed for a fan only installation.
Retired Navy
Old 01-31-2018, 09:21 AM   #5
I already contacted them. The service rep said she couldnít recommend anyoneís a/c unit. Thanks
Old 01-31-2018, 10:29 AM   #6
I believe there is usually a size difference on the ceiling assembly air distribution panel between ducted and non-ducted. We used a low profile Penguin II ducted and the inside portion is fairly small. Might check out the dimensions on their webpage. Good luck!
Old 01-31-2018, 11:29 AM   #7
Ya. The one I need will be non-ducted. Great. Thanks
Old 01-31-2018, 11:36 AM   #8
Just curious as to why non-ducted? In my limited experience (installed second a/c on two different units) the units that were pre-wired also had access to the duct system. Just had to remove blocker plate and/or insulation.
Old 01-31-2018, 11:42 AM   #9
Iíll have to check. I didnít see a blocker plate in there when I took the vent out. Iíll double check tho. Thanks
Old 01-31-2018, 11:46 AM   #10
I have read that in some units, the 'duct' is just a gap in the hard foam insulation. Might check if your existing vents are attached to an actual duct or not.
Old 01-31-2018, 12:11 PM   #11
Support from Forest River just returned my call. Itís gotta be a non-ducted unit.
Old 01-31-2018, 12:15 PM   #12
AquaMan's Avatar
I would say that in most units, the duct is just a channel in the ceiling and the the vents are only connected to the ceiling material itself. If you look at the vents, they are usually in a fairly straight line front to back. See what side of the hole the vents are on and knock out that block to access the channel. If you want to double check before knocking the block out, drill a hole in it, plug a few vents, and turn your existing ac fan on. You should feel the air.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 01-31-2018, 12:26 PM   #13
Well dangit. It was worth a shot
Old 01-31-2018, 12:45 PM   #14
rracer5's Avatar
This is true however, there needs to be a "return air" duct running from side to side. Two return air vents then have to be cut into the ceiling just inside the 2 outer sidewalls at the ends of the return duct. To do this type of install correctly probably would require pulling ceiling panels down to install the return duct system & tie into the existing cold air outlet duct system.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 01-31-2018, 01:06 PM   #15
Return air routed through 14" x 14" hole a/c and ceiling attachment (air distributor) is mounted to.
Old 01-31-2018, 01:20 PM   #16
Thanks guys. Found a solution.
Old 01-31-2018, 01:38 PM   #17
Share solution please!
Old 01-31-2018, 01:40 PM   #18
AquaMan's Avatar
I concur!
Old 01-31-2018, 03:43 PM   #19
Coleman Mach 3 with series 9000 ceiling air diverter/controller. Small enough to fit between wall & roof cutout.
Old 01-31-2018, 04:52 PM   #20
Casey & Carolyn
Casey r's Avatar
Scott
What did you do about a thermostat. I have not looked at the duct work but I did pull out the vent and I have 110 volts there no other wiring. I assumed since I did not see thermostat wiring it was not ducted. I did see thin pylwood on the side that would be closest to the ducting but did not remove it. Wanting to add second a/c.
Casey and Carolyn Rice
Las Vegas Nv
2017 Prime Time Crusader Lite 29 RS
2018 Ram 3500 4x4 CC Cummins Powered
Casey r is offline   Reply With Quote
air conditioner
