Old 08-25-2013, 02:48 PM   #1
301 RLS TV mount
Has anyone installed a TV on the pre-exsisting mount? I bought a 22" flat screen to install, but I should have asked here first if I need to buy any attachments to install it. Thanks in advance for the help.
Mike
MikeD71 is offline   Reply With Quote
Old 08-30-2013, 07:26 PM   #2
DS ADV Rider
Yes, I took out the Legend 26" and installed a JVC 37". It has a very narrow bezel around the screen and is the max size I could install - only about 1/8" clearance at top and zero at bottom.
I kept the existing wall mount but bought a simple non-swivel wall mount at Marshall's (the clothing discount store!) and drilled a couple of new holes in it and installed it on the existing mount.
I moved the metal fittings for the tie-down straps to the rear wall and it all works great
Bob
Lacrosse 301RLS Touring Edition
GMC Sierra SLT 2500 4X4
BMW F650GS Dakar
Suzuki DR350SE & Suzuki DR650SE
Specialized FSR XC Comp
DualSport is offline   Reply With Quote
Old 08-30-2013, 07:32 PM   #3
DS ADV Rider
Hmmm - you want to install a 22" TV, so I'm now wondering if you mean the bedroom TV mount?
If so, then the answer to that is also YES. I bought a Samsung 24" LED and mounted it to the spare TV-mount-adapter provided by Prime Time. It then just slides into the ceiling mount and works fine on the standard cable/antenna setup. However I did modify my wirng so as to also be able to watch Satellite TV in the bedroom or outside (although I haven't found the need for either ).
Some owners have posted they didn't get a spare mounting plate but it is supposed to be provided as it's a custom mount.
Bob
BMW F650GS Dakar
mount, tv mount
