Old 05-22-2016, 08:32 PM   #1
30bh battery disconnect?
Some friends of ours have a 30bhs and it is acting like their is a battery disconnect that is disconnected. Landing gear slides work but nothing else works off battery. I told them I would stop on my way home tomorrow and try and help them so if there is a disconnect and where it is would be great if anyone can help. If not I am going to trouble shoot the relays...any other ideas would be appreciated.
2017 Brookstone 395RL
Chardon OH
cwc510117 is offline   Reply With Quote
Old 05-22-2016, 10:39 PM   #2
rracer5's Avatar
Not sure if it has relays. But check for them. Some are resettable. There is a tiny button on the side of it. Hard to see, you're better off feeling around for the reset button.......good luck.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 05-24-2016, 07:50 PM   #3
So if it ever comes up for anyone the 30bh does have a battery disconnect and it is located in the water hook up compartment.
Chardon OH
Old 06-19-2016, 02:30 PM   #4
I had the same issue last week, I wanted to put the slide out in and nothing worked , it's crazy since my 370 bhq is only 3 weeks old and never used but out of the blue it just worked.
Thanks again forest river for another issue I have to investigate.
Ronleague is offline   Reply With Quote
Old 06-19-2016, 02:37 PM   #5
Our same friends about 3 weeks ago slide stopped working...I cut the wires to it and we ran the slide out on a battery. Long story short when they took it in the hot wire going to the slide switch had come loose.
Chardon OH
battery, battery disconnect
