Old 11-10-2011, 02:49 PM   #1
Vols's Avatar
3150bhd furnace use
can I use the furance when not hooked up to shore power? if so, is it as simple as just setting thermostat like normal when hooked up at cg?
Vols is offline   Reply With Quote
Old 11-10-2011, 02:55 PM   #2
MtnGuy's Avatar
Yes, it will work the same way. But beware, the furnace will draw your battery down real fast.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
Old 11-10-2011, 04:47 PM   #3
You should be able to make it through one maybe two nights on your battery. Make sure you keep your frig on gas and not auto. That also seems to drain the battery a little faster. I bought a champion 3500 watt generator for $279 at Cabelas last year. Works good and not too noisy. I take it along when boondocking and saves me the worry about draining my battery.
2011 Lacrosse 318BHS Touring Edition
2012 Ford F150 SupCrew 4x4 XLT 6.5' Max Tow
padave65 is offline   Reply With Quote
