Old 03-30-2012, 04:50 PM   #11
Commercial Member
6.4 is correct on fresh tank placement.
RV Guy is offline   Reply With Quote
Old 03-31-2012, 01:41 PM   #12
rracer5's Avatar
Man, that photo is worth a thousand words, sure helps explain a lot. I can now see how the galley and grey are plumbed together. Except in the 303 RKS (rear kitchen) the galley tank is mounted all the way to the rear under the kitchen sink and it's a long way to the dump valve. That's why it can take awhile for the galley to drain completely in the 303 RKS. The slope of that long section is minimal so I fould it's better to be "nosed" down to facilitate faster draining.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 04-06-2012, 11:01 PM   #13
Wait so I have a galley tank and a grey water tank? I only have 2 drain levers...one for grey water and one for black water...unless I am missing something....my old Montana had 3 levers ...one for galley one for grey and one for black...can so done help me out on this one?
2015 Dodge 2500 Big Horn 4x4 6.4 HEMI
2015 Grand Designs Reflections 323 BHS
Reese 16K Quick Slide with Factory Rail Kit Option
kozzy is offline   Reply With Quote
Old 04-06-2012, 11:12 PM   #14
TURBS's Avatar
dont feel bad kozy
I have 2 levers and 5 tanks ! well 4 waste tanks and one fw tank
so when I pull up to the dump station I have to do it twice since there about 8 or so feet apart which makes me have to dump front two then move ahead 8 feet and do it again !
Old 04-06-2012, 11:16 PM   #15
I do nt feel bad...i guess I'm just trying to figure out if I do infact have a galley tank and a separate grey water tank....are they both drained by the single grey water lever? And if so...why did my dealer never tell me this..or why is it not in any documentation from prime time? What are the tank capacities? I have a 318 BHS and am clueless...I'm confused...I think I'm getting a headache hahaha
Old 04-06-2012, 11:21 PM   #16
TURBS's Avatar
can you see your pipes coming to your outlet ?
the galley may be tied into your grey . someone will know the specific answer since I am not to versed on prime time .
actually according to your prime time brochure you have 60 gallons of grey so I would say you have a grey and a galley both tied into each other.Prime Time Manufacturing, Manufacturers of travel trailers and fifth wheels
Old 04-06-2012, 11:43 PM   #17
More for me to investigate tomorrow. Bed time. Haha. I'm guessing if it is 60... Then I probably have to 39 gal tanks. And no I can't see my pipes. The underbelly is all enclosed. All that sticks out is the outlet drain
Old 04-07-2012, 07:27 AM   #18
6.4 tow rig's Avatar
Yes the Lacrosse has two gray tanks, the galley and the gray. The kitchen drains to the galley, thats why its up front in the picture I posted. The shower and bathroom sink drains to the gray tank. Its in the middle on the picture, and obviously the toilet drains to the black water, tank to the far left. The water from the outside kitchen sink also drains to the black water. On my 2013 the monitor panel has galley, gray and black listed. However the issue is since the galley and gray are connected with an 1.5 pipe from the bottom of one tank to the bottom of the other they both fill at the same time depending on how level the trailer is sitting. So really having two monitors for gray and galley doenst do much. One will read the same as the other and thats also what makes the 60 gallon capacity. Primetime has been great about explaining this to me in emails and sending the pic I posted earlier
EDIT: I forgot to mention that since the two tanks are linked together they use the same drain point, thus you only have one gray tank lever.
6.4 tow rig is offline   Reply With Quote
Old 04-07-2012, 09:43 AM   #19
Wonderful...thanks for clearing that up for me...no more headache today haha
318bhs
