Old 05-03-2012, 02:38 PM   #11
Commercial Member
Contact Roger at rstickel@forestriverinc.com
RV Guy is offline   Reply With Quote
Old 05-03-2012, 03:00 PM   #12
That's the guy that helped me...very helpful
2015 Dodge 2500 Big Horn 4x4 6.4 HEMI
2015 Grand Designs Reflections 323 BHS
Reese 16K Quick Slide with Factory Rail Kit Option
kozzy is offline   Reply With Quote
Old 05-08-2012, 02:45 PM   #13
Originally Posted by RV Guy View Post
Dwayne, you shouldn't have a problem with that order. Sorry you were denied.
Tried to order again but PT wants me to measure the cabinets myself and/or provide pictures. I don't have access to my trailer right now. Should I need to really do this for my 2670BHS? I assume PT would have all the info they need. Roger was able to look me up in their system and has my VIN.
Dwayne
dapersico is offline   Reply With Quote
Old 05-08-2012, 03:07 PM   #14
cre10's Avatar
Dwayne
Personally I would not want to order without measuring to make sure you are getting exactly what you need.
2012 Chevy 3500 Duramax Crew Cab Z71 LTZ SRW
2012 Cherokee Grey Wolf 28BH
2011 F-250 6.2 Gas
2001 F-350 Powerstroke
1995 F-350 7.5L 460
Numerous Ford and New Holland Tractors up to 135hp. Bobcat 773.
cre10 is offline   Reply With Quote
Old 05-08-2012, 09:34 PM   #15
I agree. I measured and the ones they had n stock from a different model fit mine. I'm hoping to do my install on Thursday. If your dinette is the same size as mine, the size I got should fit....I believe they Are 12" x 22 " but I'd have to check again
Old 05-09-2012, 10:23 PM   #16
Well just finished my install came out great. I can't decide weather to put on the handles or leave them off for the clean look...right now they are off. This took about an hour and was very easy....the first pic is the before pic...the rest are the after. I only posted the left side of the dinette...you get the idea.
The before pic...
After...door closed
With the door ope, access with out moving the cushions...
ID:	13516   Click image for larger version
ID:	13517   Click image for larger version
ID:	13518   Click image for larger version
Old 05-10-2012, 08:18 AM   #17
cre10's Avatar
Looks good.
2011 F-250 6.2 Gas
1995 F-350 7.5L 460
Old 05-10-2012, 08:54 AM   #18
Looks great!
Could you confirm the measurements you provided earlier? I would like to compare them to mine as soon as I get my unit back from the dealer.
How did you cut out the thin panel from the dinette?
Dwayne
Old 05-10-2012, 12:37 PM   #19
The doors are 12" x 24 ". And I didn't have to cut the panel at all..it is just stapled in...i used my fist and lightly tapped around the edges and it came out pretty smoothly...
Old 05-11-2012, 10:14 AM   #20
Commercial Member
Dwayne - maybe I wasn't paying attention fully but I assumed you had a 318 LaCrosse given the thread title - my fault for assuming.
The reason for the strange question from Roger is we do not currently offer doors for the dinettes on Tracer. We started using them on LaCrosse so we know what door that would be. I didn't even realize we were trying to get Tracer doors special ordered for customers. Even I learn something on these boards
Kozzy - I would be very careful with installing any type of handle on these doors. When your s/o comes in, one of your doors is going to be VERY close to your bath wall. The wrong handle could hit.
318bhs
