Old 06-08-2014, 09:17 PM   #11
electroblast's Avatar
Thanks zs325RES
I used the TV antenna from the bedroom with and adapter to connect to my radio, Bingo, all work fine now. Since we do not have a TV set in the bedroom, why not using that outlet.
So Thanks zs325RES for the input.
electroblast is offline   Reply With Quote
Old 06-10-2014, 09:49 AM   #12
zs325RES's Avatar
Originally Posted by volwing1 View Post
the F fitting does not mate with my RCA ant. terminal. I soldered a coax to the FM ant wire and connected to the roof ant TV connector.. no reception improvement. The coax center wire was the one soldered.
I have to clarify - it was not an 'F' connector, but a slip-on (not screw on) coaxial connector. These are the cheap-and-dirty versions of coaxial connectors. I had a short 6' cable with these ends on that worked well.
Make sure you tap into the 'output' of your antenna amplifier.
@Electroblast - Glad it worked. Happy to have helped by sharing.
2013 Crusader 325RES Touring Edition
2006 Silverado 2500HD LT SW ECSB, 6L LQ4/4L80E 4.10s w/16K Curt slider (not necessary), Air Lift bags & Black Bear Performance tune & CAI
Norm & Karen Zondervan
zs325RES is offline   Reply With Quote
antenna, radio
