Old 06-10-2014, 04:40 PM   #11
Hay all, sometime back when I found exposed wood on the underside of our unit I also noticed a possible problem spot but until this past weekend pulling it home in the rain I could not tell. The lower slide seals have a L shaped plastic piece to hold the rubber and for the fasteners(screws) that covers the edge of the wood and Darco about 3/8" without any type of sealant to keep the water from getting to the edge of the wood(not sure if thats just my unit or thats a crossed the board) well the plywood edge was wet as hell so I removed the entire seal,cleaned,and sealed it with rubber undercoating. next weekend I will seal the edge of the seal just for added protection, like I said before I'm not sure If It's mine or there all like that but If you get time I would look.
I called my dealer to let them know I think I am starting to have a front flex problem(warranty ends 6/26/14)sent them pics and the loaded pin weight so I will see how this turns out. We love the camper and other then the noted problems in this thread I have not had a single problem with anything and I hope It stays that way Take care. Keepaeyeonit
Name:	photo 2 copy.jpg
ID:	54902   Click image for larger version
Name:	photo 3 copy.jpg
ID:	54903   Click image for larger version
Name:	photo 1 copy.jpg
ID:	54904   Click image for larger version
ID:	54905   Click image for larger version
2014 Crusader 335BHS-TE
2017 F-350 6.7L CC flat bed
Nights Camped in this unit.
2017 3 so far
2015 57/2016 52
2014 40/2013 38
keepaeyeonit is offline   Reply With Quote
Old 06-10-2014, 09:48 PM   #12
Platokidd's Avatar
Thanks for the seal pointers... good luck on the front end and do keep us posted
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
